Old 03-28-2018, 07:20 AM   #1
Crossfire tire pressure sytem
I’m thinking of adding this system to my 08 Georgetown XL. It was recommended to me by my tire shop. Seems affordable and better than extensions.
I’d appreciate any feed back from folks regarding the good, the bad and ugly.
Thanks.
Pkowski is offline   Reply With Quote
Old 03-28-2018, 07:31 AM   #2
W5CI's Avatar
I ran the Cross Fires's for years and Millions of miles without a problem, in short they Work. be sure and buy the correct pressure rating for your tires. they come in different pressure ratings. they make it so easy to check your TP, just walk buy and look a each wheel.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 03-28-2018, 08:23 AM   #3
From what I researched they seem simple to install and you can’t beat the price. Thanks for the tip about the ratings.
Old 03-28-2018, 08:31 AM   #4
AquaMan's Avatar
Looked into these and watched a couple videos. Seems legit. Saw one video where a guy added 2 tpms sensors to the system (1 for each tire) to monitor pressures individually instead of the system as a whole, because it wouldn't show a blowout because of isolation.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 03-28-2018, 03:44 PM   #5
RudysWorld's Avatar
I have used them a couple of years and work fine. Much easier to air tires with one valve for both rear tires.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 03-29-2018, 08:16 AM   #6
Does anyone have a way to order different pressure Crossfires? 60 psi is too low. 80 psi is too high. need 70 psi Crossfires.
Iowaprism is offline   Reply With Quote
Old 03-29-2018, 08:47 AM   #7
AquaMan's Avatar
https://www.newegg.com/Product/Produ...9SIAC284V66274
Try this.
Old 03-29-2018, 10:35 AM   #8
RudysWorld's Avatar
Also available on ebay:
https://www.ebay.com/itm/CROSSFIRE-T...-/272377391600
Good Luck!
pressure, tire
