Old 06-04-2014, 08:06 AM   #1
Fireman
Send a message via AIM to dutch
Dash entertainment center
Can anyone help me we bought a 2013 378XL Georgetown last year, and just last weekend we try to play a DVD movie in the entertainment/camera/radio/DVD player on the dash which is a Clarion ( do not know model) I cannot find any manual for it, in all the manual the dealer gave us, does anyone have a copy of one or know where I can get one? the reason we are asking is using the remote that came with it we cannot get the movie to play on the tv screen. we pushed every button on the remote. HELP and confused.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 06-04-2014, 11:00 AM   #2
Have you changed your TV to the correct input. Not sure what your menu looks like, but it's usually one of these ANT/Cable, Video 1, HDMI, etc. The TV's remote usually have a button marked "Input". Switch through it until you see the picture from the DVD player.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 06-04-2014, 11:02 AM   #3
tncruiser's Avatar
on my 280 i have a separate cd/dvd/am/fm system my dash unit only plays radio and cd's
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 06-04-2014, 06:37 PM   #4
Krazymace's Avatar
Think you have to put the Clarion in AUX mode.
Krazymace is offline   Reply With Quote
Old 06-04-2014, 06:59 PM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
Clarion U.S.A | Multimedia
Check their site, does anyone of these look like yours? At the bottom of the page there`s a place for manual downloads. Hope this` might help.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 06-05-2014, 08:21 AM   #6
Fireman
Charlie,
Thank you for the web site. I down loaded the manual for VZ401 which is what we have. I will try to do a DVD on the TV when I get back home today.
Old 06-05-2014, 01:19 PM   #7
cfsoistman's Avatar
Originally Posted by dutch View Post
Charlie,
Great, glad you found what you needed.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 06-05-2014, 06:53 PM   #8
camaraderie's Avatar
Dutch...a couple of notes...the ONLY output from the clarion that provides external video is a black wire with a YELLOW RCA jack... another RCA cable should be plugged into that and then into ONE of the yelllow input jacks on your TV which should be accessible via the input switch on your TV remote control as one of the choices.
The other possible glitch is that the parking brake may be wired to "must be engaged" before you can see the video overhead.
If the easy stuff doesn't work, I'd try to do a continuity test on the yellow radio jack to the back of the TV wire before sending the unit in for warranty work. I note lots of the sound problems here end up being factory mis-wiring or oops I forgot to attach that wire kind of stuff which is easily fixed once found.
Good luck!
camaraderie is offline   Reply With Quote
Old 06-13-2014, 11:47 AM   #9
We found that we have to point the remote at the dashboard unit in order to control the TV. Actually, our much more tech-savvy 14 year old grandson figured it out. It's counter-intuitive, but it works.
CindyB
2014 Georgetown 329DS
CindyB is offline   Reply With Quote
Old 06-18-2014, 02:50 PM   #10
macevoyj's Avatar
I can share with you my experience with the clarion unit in my GT XL-2014: to play a cd movie the TV set needs to programmed to video. TV remote. Input button will guide you. Step 2 the dash radio switch needs to be ON. All functions for the cd are done through the clarion remote and not the tv remote! To turn up the volume is through the clarion remote pointing of course to the tiny clarion sensor. Make sure the ignition keys are out and parking brake is fully set. ( I believe this is a safety issue so your not watching a movie while driving on the small screen.). Good luck!
macevoyj is offline   Reply With Quote
