Old 06-13-2016, 02:22 PM   #1
borba's Avatar
Dash loose on drivers side
Hi everybody I have a little problem drivers side corner dash pad is lose need help fixing if anybody nows haw is it screw down or glued any help will be much appreciate thanks
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 06-14-2016, 12:23 PM   #2
I had the same problem, the dash would "float" up and down.
There is a simple fix, just push the dash up a little from under the hood
and squirt a little "great stuff" expandable insulation under the dash from under the hood. The great stuff will expand as it dries and will stop the dash panel from moving. Do not use too much or it will oooz up between the dash and windshield as it dries. Have some solvent ready so if it does you can clean it up before it dries, the instructions on the can says what kind of solvent to use. Be careful if u have to clean any up off the dash as the solvent can damage the covering on the dash if you do not use it sparingly or rub too hard. If any sticks out after it dries it can be trimmed off with a knife.
Jim G is offline   Reply With Quote
Old 06-14-2016, 02:12 PM   #3
borba's Avatar
thank ( Jim ) I will try that this weekend
2013-ford fx4
2009-harley flhx
Old 06-14-2016, 05:13 PM   #4
Another fix is what the factory reps do a the rally
They drill a few small holes through the fiberglass from under the hood and use 1/2 " wood screws to fasten it down.
Mine did the same thing, not anymore
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-15-2016, 03:34 PM   #5
borba's Avatar
( wrapperman ) thank you wen I get back home I will try the screws because am kind of a messed guy with foam
2013-ford fx4
2009-harley flhx
