Old 03-17-2015, 02:00 PM   #1
siskom's Avatar
Dash Modification 2014 335 Georgetown
Don't know about you all but I needed something more in my MH then Forest River provided. I redesigned a new center console dash removing the back up monitor to a separate mount on left side of dash then removed the black plastic center dash and made one with the correct size holes and moved switches where I thought they should go. I added a new model EONON G2110Z Android radio at top close so I could reach. Unit has GPS,Bluetooth for answering phone hands free and so many more options to make our life easier. Had fun doing it!
siskom is offline   Reply With Quote
Old 03-17-2015, 02:08 PM   #2
GABoy's Avatar
I don't see anything. Where's the pics?
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 03-17-2015, 02:11 PM   #3
siskom's Avatar
sorry just added pic
Old 03-17-2015, 02:25 PM   #4
GABoy's Avatar
Cool like the wood look!
You got pics where you mounted the old screen? I have an old pioneer nav double din radio. Thought about doing something similar. Like the idea!
Chevy Colorado Crew
Old 03-17-2015, 02:41 PM   #5
siskom's Avatar
old backup screen
Back up screen was 2 inches taller than double DIN therefore new panel it has 5 coats of clear on it.
Old 03-17-2015, 03:50 PM   #6
bigben's Avatar
Very nicely done!!!
US Army - Retired and loving it with our Georgetown 351DS and now our Thor Challenger 37TB.
bigben is offline   Reply With Quote
Old 03-18-2015, 01:03 PM   #7
The Wandering Irishman's Avatar
That looks fantastic! I've been wanting to move things around also, but never thought of using wood - I was trying to find similar plexi-glass material.
I'm guessing that's 1/4" plywood? Did you need to add any reinforcements to the back to help hold the weight of the stereo or monitor?
Tom
2014 Georgetown 351DS, 5 kids, 2 dogs, and an amazing wife!
The Wandering Irishman is offline   Reply With Quote
Old 03-18-2015, 01:36 PM   #8
siskom's Avatar
Lowes carries 1/4 inch oak plywood and has finished sides. what i used for mounting of the radio was plastic J channel. if you have never used it it is by the soffit and facia section it looks like the letter J the small part of the J is rigit and the tall part of the J has holes in it and is about 2 inches long. I used some 3200lb epoxy comes in two tubes that mix when being applied. I used my old plexiglass panel as a template for the switches and went to automotive store and got a kit for putting in radios it had the glove box in it. once I cut switch and hr meter holes then i figured out where and how big to make radio and glove box holes. cut them with a jig saw slowly sanded then stained then got the gloss clear in spray can it covers smoother applied one coat dry for two hrs light sand 220 grit then coat again, I put 5 coats on. Hope this helps.
Old 03-18-2015, 03:10 PM   #9
Bubbamace's Avatar
Wow, fantastic job ! Its beautiful and functional also.
Bubbamace is offline   Reply With Quote
Old 03-18-2015, 06:19 PM   #10
camaraderie's Avatar
Neat ideas and work! Thanks for sharing.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
georgetown, cat, 2014, modifications
