My parents have a class A diesel pusher and it has two small drawers just to the right of the driver in the center of the dash and I always wondered why more rv manufacturers didn’t do something similar, I did see at a rv show one of the new 2018 class A gas burners had a large drawer built into the center of the dash and it was designed in a way that you didn’t even know it was there and you had to push in on the drawer which would make it pop open.. I was pretty cool! I wanna say it was a new Jayco precept but I can’t remember for certain.
I happened to find a small wooden magazine holder that’s roughly 12” wide x 16” tall and about 4-5” deep with a wooden hinged lid on the top that closely matched the wood work in our coach and I attached it to the floor under the drivers side window just between the seat and the dash and it works well! I’m pretty sure i got it at either Home Goods or the Container Store but a google search or a trip to a IKEA may work too.
As for the gps I went to Best Buy and found a dash mount for a garmin that had a large stiff rubberish foot on it that is designed to just cling to the dash but I removed the rubber foot thing and placed a piece of industrial Velcro cut to match the metal piece the rubber foot was attach to and then attached the other side of the Velcro to the top center portion of the dash right in between the drive and passenger seats, that particular mount swivels left, right and up and down and the wife can easily turn it towards her to enter an address. I bought a hardwire kit from eBay for our gps and drilled a small hole in the dash just behind the mount and wired it to the 12v outlet.. it has worked perfectly for almost a yr now! It’s called a garmin friction mount and it’s Model: 010-11280-11 and as long as the gps you are using has the socket on the back of it that a small ball snaps into to mount the unit to the mount it came with it should work. Most gps’s use that same ball mount. I think I paid $20 for it.
Take Vacations.. Go as many places as you can!
You can always make money..
But you can't always make memories!
