Old 01-23-2014, 06:29 AM   #11
Great pic and diagram!
fullenw is offline   Reply With Quote
Old 01-23-2014, 07:50 AM   #12
Carmel's Avatar
Mine only has one valve. Never had an rv like that, still not sure how 1 valve can bypass the water heater ?????
Carmel is offline   Reply With Quote
Old 01-23-2014, 11:45 AM   #13
With the use of check valves:
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 01-23-2014, 01:51 PM   #14
Carmel's Avatar
Thanks al now it makes sense
Old 01-23-2014, 02:55 PM   #15
No problem. I originally thought I had the one valve system, as I was told by the salesman. Come to find out, I had the three valve system.
Old 01-25-2014, 02:59 PM   #16
Tim & Lisa Trempert
One comment on de-winterizing. Make sure you get all the pink stuff out of your lines BEFORE you turn the hot water bypass off. I found that if you don't, you will get foamy hot water for a long time before it finally dilutes the residual antifreeze to where it doesn't react with the anode.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 01-25-2014, 03:53 PM   #17
+1
Old 01-27-2014, 11:29 AM   #18
Kracymace, as you view and use this forum more often you'll find your owner's manual growing with all the good insightful information that can be harvested from those who may of experienced a particular issue in the past. Good Luck with your rig!
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
winter, winterize
