Old 07-04-2009, 03:57 PM   #1
Dead Circuit
I have a 2003 346 8.1 workhorse. I have a circuit that has 4 elec.boxs on it that is dead. Check all breakers and none is trip.Put a meter on the breakers and all show 120. One of the box is inside of rear cabnet for rear tv. one is next to the front A/C termostat in the hall way.One is out side for the frige.
I notice this circuit was out after i clean the house batteries post.
thanks
William
williamp321 is offline   Reply With Quote
Old 07-05-2009, 04:05 PM   #2
NWJeeper's Avatar
Look for a tripped GFCI outlet. More than likely that run of outlets is GFCI protected due to the refrigerator oulet being on the "outside" of the coach. Depending on how they are wired a GFCI outlet can be made to protect all outlets downline from them so if it trips then all the others will be dead.
Ed & Wendy
www.nwjeepn.com
Old 07-28-2009, 08:50 PM   #3
Found the problem
Have the push in type elec receptacles for the wires. One of the wires came out.We had been on some ruff roads. But in a new receptacle and it fix.
