Old 03-09-2015, 10:50 AM   #1
deannelsonrn's Avatar
Decals Bubbling ALL over RV
I just got my 2012 351DS out of storage and look at what I found!....Maybe 100 bubbles ALL over my RV.I have taken nothing but great care of this RV....has anyone ever had this problem?....Did you get it fixed?....Was it under warranty?....
ID:	71004   Click image for larger version
ID:	71005   Click image for larger version
ID:	71006   Click image for larger version
ID:	71007   Click image for larger version
deannelsonrn is offline   Reply With Quote
Old 03-09-2015, 11:08 AM   #2
bubbles's Avatar
Chances are that a straight pin (pricking and pressing down) would be the tool used by a repair facility but you can do that and save time and travel. Of course it's your call. Don't think warming up will make them go away but maybe so.
Old 03-09-2015, 11:15 AM   #3
Coach 350's Avatar
You have air under the decal causing this. Get a small pin and hair dryer. Slightly warm the area and Pop bubble. Use a credit card to smooth surface out. Saw a pro do this in a sign shop. If it is under warranty, this is what the dealer would do.
Coach 350 is offline   Reply With Quote
Old 03-09-2015, 01:56 PM   #4
yep, 3C is right. I make vinyl decals for sign shops and it is odd that they weren't there before and they appeared after storage. let it sit in the sun for a couple of days to get warm and re-check. That's a lot of bubbles to prick and flatten. If you chose to do that, put a piece of freezer paper over your decal before smoothing out the vinyl with your burnishing tool (credit card, squeegie, etc) so you don't make a mistake and catch the edge of your cc on a little hole and tear the vinyl.
However, if it's still under warranty, I would definitely contact them to repair. It should not be doing this and any holes/pin pricks you make may null that warranty repair.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 03-10-2015, 12:35 PM   #5
dicky1243's Avatar
Bubbles I hate to disagree with you but that process would allow moisture to infiltrate in behind the bubble, My experience at 3M was when we put decals on trailers we would use a heat gun and a roller tool to shrink the vinyl to adhere to the siding of the trl. this will work in your case as well, it just takes a little patience to do all. Its cheap add effective.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 03-10-2015, 12:40 PM   #6
dicky1243's Avatar
You're on the right track with the heat but easier to use a heat gun and roller like 3M does on their decals faster than waiting for the sun to maybe get the job done
2006 Gmc
Full Timers
Dick,
Old 03-10-2015, 12:43 PM   #7
WDK
WDK's Avatar
......that sounds so scary to me.....I have tried that pin pricking idea on other stuff....not my coach and perhaps while a pro may do the same.....all it takes is one wrinkle in just one bubble to piss you off because unless you remove the decal and start all over, your only going to get one shot at each.
WDK
WDK is offline   Reply With Quote
Old 03-10-2015, 12:44 PM   #8
dicky1243's Avatar
Dean, 3M uses a low heat gun and a roller to get rid of the bubbles some you can role to the edge practice on an inconspicous spot this is what i do.
2006 Gmc
Full Timers
Dick,
Old 03-10-2015, 12:49 PM   #9
dicky1243's Avatar
WDK
True pricking is not good it will allow moisture in behind and cause worse problem 3M uses a heat gun and a roller to get rid of the bubbles on the trailers we put decals on.
2006 Gmc
Full Timers
Dick,
Old 03-10-2015, 12:56 PM   #10
Team Bleu
My sister did on her FR3, FR replaced and it also need a paint job in places, swirl marks were coming thru the paint.
DBsRedVett is offline   Reply With Quote
