Originally Posted by speedjester
Well I'm going to try and re caulk all the seams... Ordered 8 tubes of Dicor self leveling..(hope it's enough?)
I know it's self leveling.. How thick should it be put on??
l can do all the roof seams on my 34' with 1 or 2 tubes of the self leveling and 1 tube of the non sag for all the wall areas. You'll have pleanty for the years to come.
You will see the self leveling levels more in high heat but is slugish this time of year in Ohio.
Start with an area other that a seam (like the skylight or antenna base) to get used to the flow and leveling speed. You will want just enough to cover the area in 1 coat.
crunchman
