Old 10-14-2016, 09:52 PM   #1
digital channel tuning?
WE have a 2010 Georgetown 350 with a Toshiba TV. Does any one know how to tune the digital channels on cable hookup? I seem to only get analog when auto tuning? The TV manual states I can get digital??
R&S
201 Georgetown 350
2013 Honda CRV toad
rstoro is offline   Reply With Quote
Old 10-15-2016, 08:06 AM   #2
cjd10's Avatar
I thought all of the channels are now digital. My Toshiba TV says it is scanning analog and digital but I just assumed everything it was picking up was digital.
There is a different selection on the TV for scanning channels from the antenna or cable however.
2014 Georgetown 351DS
Charleston SC
3 Boston Terriers, 1 Frenchie
Gonna miss you Toby. RIP
cjd10 is offline   Reply With Quote
Old 10-15-2016, 08:14 AM   #3
CANADA FROG RALLY 2017
B and B's Avatar
A lot depends on the cable system. Most basic cable is legacy analogue equipment. The premium channels are digital in many cases. Where i live there is no analogue cable any longer and you are forced to rent a digital terminal for TV. The only analogue channel is the aquarium channel.
I went satellite 20 years ago and have not looked back either at home on on the road.
OTA TV is for the most part Digital but there are some LPTV installations still analogue, religious or local mom and pop operations.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 10-15-2016, 08:53 AM   #4
KyDan's Avatar
As mentioned- make sure your TV is set to cable not air/antenna and many
camp grounds have analog cable so that could be the reason. Do you get
digital when you use your antenna? Most/all broadcast TV is now digital.
Our last trip the CG had analog cable but we could get all major networks
with our antenna so we opted not to use the crummy cable signal.
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44
Old 10-15-2016, 09:36 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
When I scan at a CG it says analog and digital. I do get standard definition and high definition channels on most systems. You will see a difference in quality but it covers more channels choices at the campgrounds.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 10-15-2016, 05:09 PM   #6
I think the problem we have is like KYdan states... the cable in some of the campgrounds. I can get digital stations sometimes and also over the air channels (when I can pick them up)we upgraded to a new tv in the bedroom and that seems to pick up the digital channels when the older Toshiba doesn't??
R & S
2010 Georgetown 350
