Old 06-20-2015, 09:46 AM   #11
Originally Posted by Marvlab View Post
Thanks for the install info. We have a 2011 337ds. I like the idea of under the bed but have some reservations as to the length of vac hose maintaining good suction.
We use the hose that came with the Dirt Devil Vacuum Cleaner so wherever you mount it the hose will still be the same length. As ours is installed under the bed it will still, almost, pick up a bowling ball.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 06-20-2015, 05:10 PM   #12
Just an update, I ended up installing the vacuum motor in the bay with the gfi outlet. I ran the hose through the top of the bay next to it and put the outlet in the stairwell. I took a couple of pics. I'm happy with the result and most importantly so is my wife. Thanks for the input. And now on to the next mod.......
Name:   ImageUploadedByForest River Forums1434838124.741513.jpg
Name:   ImageUploadedByForest River Forums1434838162.543815.jpg
valentinecreekfarm is offline   Reply With Quote
Old 06-22-2015, 07:18 PM   #13
328TS place for a vac
After looking over my coach and taking some photos, I think I have a solution on where to mount the thing.
Use an Intervac RV vac that sits sideways.
Put it under the sink, on the floor by the fridge.
Run power up from the fridge inverter, no hoses to mount in a kitchen slide.
Life is good, I might even add another outlet in that spot to have 120V AC when on battery power, yes I know that I am limited, but it should power a laptop or a similar device.
The only thing I have not figured out is what looks a plastic tank above the bay that holds the inverter - water tank ????
Poor photos follow..
ID:	80786   Click image for larger version
ID:	80787   Click image for larger version
ID:	80788   Click image for larger version
happywhencamping is offline   Reply With Quote
