Old 08-25-2013, 04:09 PM   #1
Question Disable pump for jack replacement
Does anyone know if there is a fuze that I can pull that would disable the hydraulic pump? Good Sam service came to my driveway to remove my bent jack so I could drive to my repair shop. When I started the engine and put it in drive the system started screaming trying to pull up the jack that wasn't there and pumped out my reservoir on the ground.
johnnypal is offline   Reply With Quote
Old 08-25-2013, 06:44 PM   #2
Iggy's Avatar
Yes it is the 100 amp reseetable breaker that is located under the steps to the left of the control box.
It has a red button and a red flag that pops out to show it is tripped.
You can also disconnect the Positive battery cable from both batteries.
Old 08-26-2013, 07:24 AM   #3
Thanks Iggy, what would this forum do without you.
Old 08-27-2013, 01:27 PM   #4
BigGeorge's Avatar
I don't know, the man knows EVERYTHING! (Smile)
BigGeorge is offline   Reply With Quote
Old 08-27-2013, 01:54 PM   #5
Iggy has saved all of us on this forum a lot of money and aggrevation.I'm glad he owns a Georgetown and the forum has him.
pump, replacement
