Old 08-24-2016, 10:24 AM   #1
RVnut's Avatar
Do it yourself oil changes
So this is our second MH and we love the 364 but if you do your own oil changes how do you get the fresh oil back in the motor.. That fill tube is up so high and close to the dash area it is next to impossible to get a funnel in their.. What have you found that works.. I am not paying $200 again for an oil change
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 08-24-2016, 01:43 PM   #2
I searched around my area and found a local Ford house to change the oil and filter for $52.50 with everything included.
I also found a large truck service center that did it for $12.50 if I bought the oil and filter from Walmart and brought it to them
I have ended up going to the Ford house because they are a Ford dealer
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 08-24-2016, 01:55 PM   #3
I took ours to a local Mr Tire to try out. They changed the entire oil and the invoice was around $45. It actually was cheaper than the Valvoline Care Center where I take my Toyota Mini Van. $200 is way too much!!
Now if I could just find someplace to change the oil in the generator for a not so high price.
2016 Forest River Georgetown 364TS
Browns-Camden is offline   Reply With Quote
Old 08-24-2016, 01:58 PM   #4
AquaMan's Avatar
I use qt bottles, makes life a lot easier. I've done 2 oil changes on my 364 so far. What I find more aggravating, is the drain plug is directly over the axle.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 08-24-2016, 04:53 PM   #5
Walmart sells a flexible screw on top for QT bottles that works well. You can put the end in the filler tube before you have to tip the bottle up. They are under a dollar and red in color. Just don't screw them on to tight or they will jump a thread.
revflyer is offline   Reply With Quote
Old 08-24-2016, 06:24 PM   #6
If you don't use your leveling jacks you can get an oil pan in just under the oil drain plug, haven't needed to buy any after market parts that way. Also one quart oil bottles are the easiest but you can get a 5 quart one in there if you take your time and slowly fir it in.
Watertown is offline   Reply With Quote
Old 08-24-2016, 09:23 PM   #7
RJJ
Aquaman, the Fumoto valves have a nipple to attach a tube and it drains right into the drain pan. No mess or stripped threads.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 08-25-2016, 09:47 AM   #8
AquaMan's Avatar
2014 Chevy Equinox
This is going to be my next mod!
Old 08-25-2016, 12:37 PM   #9
I am very interested in Purchasing a Fumoto valve. Do you remember what Part Number you used? I own a 2016 Georgetown 328 myself but it is the same Engine as you have. Thank you.
David L Horton
2016 Georgetown 328
dphorton is offline   Reply With Quote
Old 08-25-2016, 01:04 PM   #10
Oil change
Tractor supply has a pump for 5 qt oil jug will pump oil to engine fill valve will also remove oil from motor by suction
Dkplace is offline   Reply With Quote
Old 08-25-2016, 02:48 PM   #11
I am so glad you asked the question. I am probably going to do my first oil change either this weekend or early next week. I have never paid to have done on my previous motor home so I wouldn't have expected 200 bucks unless I took to an RV dealer.
I like the replies - yes I will have to stay to the more expensive quart bottles unless I try the Pump method as mentioned too. Didn't think of that. That could be easier.
Will wait on the Genny as I don't have enough hours yet...but that is even easier.
Mickey Alberto
2020 F350 4X4 6.7 CCLB, SRW
2020 Heartland Elkridge 38MB
cmalberto is offline   Reply With Quote
Old 08-25-2016, 02:49 PM   #12
I use a 8 foot step ladder,cut a piece of 5/8" garden hose about 2 feet long. push a funnel into it, tie wrap or tape it to the ladder with the hose in the oil filler pipe.then just pour the oil in.(slowly of course) no spills
Mark1 is offline   Reply With Quote
Old 08-25-2016, 03:07 PM   #13
RudysWorld's Avatar
I use this hand pump from Harbor Freight, works well:
Multi-Use Transfer Pump
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 08-25-2016, 03:46 PM   #14
AquaMan's Avatar
It is the 106 model. They have various sub models depending on preference. I got the 106N.
Old 08-25-2016, 06:40 PM   #15
RJJ
I got the f 106 N, but as Aquaman said there are different options. Their website is fumotousa.com. I think Amazon may sell them as well.
Old 08-25-2016, 07:46 PM   #16
Go to Harbor Freight or a tool warehouse. There is a fluid evacuator pump that removes fluid [Mighty Vac] that also reverses and pushes fluid in. Make sure to keep it clean and do not put anything else in it. We use them to fill todays trans. that do not have dip sticks and fill from the bottom of the oil pan
cotton65 is offline   Reply With Quote
Old 08-25-2016, 07:48 PM   #17
I have a 2013 351dsf I use the quart bottles
Grouch1
2013 Georgetown 351dsf
2011 Jeep Wrangler
Grouch1 is offline   Reply With Quote
Old 08-25-2016, 09:07 PM   #18
WDW
Auto Zone sells a funnel that holds fluid and has a long hose with a release valve.
Taking in the sights wherever my Trolley takes me.
2016 Coachmen Mirada 35 BH
Western NY
WDW is offline   Reply With Quote
Old 08-26-2016, 08:01 AM   #19
ron377ts's Avatar
I used quart bottle and filled it with 5 quart container. Also installed Fumoto drain valve .problem is no way to get filter off without making a mess. Filter is directly over frame rail. Tried punching hole in filter to drain oil but still poured all over frame. Fumoto valve worked great.
Ron & Joanne
Bella The chihuahua
2014 Georgetown XL 377
2007 Jeep Liberty
ron377ts is offline   Reply With Quote
Old 08-26-2016, 02:30 PM   #20
Hi, I bought a pump at Advanced Auto Parts that is made for pumping gear lube into a rear end. It comes with different length tubes. It screws right onto the 5 quart Motorcraft 5-20 bottle and putting the 10 qts in is drip free. I rest the full bottle on the w/s washer reservoir and pump away. Done in no time.
PaulRod is offline   Reply With Quote
