Old 12-04-2014, 09:32 PM   #1
Senior Member - Retired
Do You Know Which Axle & Differential You Have?
If you have never crawled under your GT XL you may be in for a surprise.
I own a 2014 GT XL 334QS. It is built on the infamous Ford F53 24K chassis, has a 228” wheel base, and came with Bilstein shocks. I have seen several of these chassis and felt I knew what I needed to know about my chassis. Using the VIN numbers as reference I ordered several items from Roadmaster including a steering stabilizer, rear anti-sway bar and trac bar. As preparations were being made to install things at the rear of the MH, it became obvious there was a problem. The axel housing is square not round as I expected and the differential is huge. Not large as you normally find with the F53 24K, but HUGE. I though perhaps it was a setup for the 26K chassis, however the leaf springs are stamped 24 not 26 so that is not it. The supplied brackets were for round axel housings, but a call to Roadmaster got brackets for the square axel housing. According to Roadmaster and a nearby Ford truck center, while it is rare, some F53 24K chassis are built with square axel housings and super heavy duty (and huge) differentials. Neither of them could offer any rhyme or reason for this, just that “sometimes it happens.” They both said I should be glad I have the much stronger setup.
Someone in this forum probably knows why this happens, however for the rest of us, before you order anything to attach to your chassis, you might want to take a look underneath to ensure you know what you have.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 12-05-2014, 01:19 PM   #2
Happily Retired Member
We have a 2013 378ts. A 24k chassis and a 244" wheelbase. I is actually a F550 chassis. Look at your VIN if it has F5D then it is an F550 motor home chassis. Search F550 on this forum and a link to F550 brochure I place there last year should pop up. These are a beast of a chassis.
Mickey & Sue Stamper
2013 GT XL 378TS
Fire Mist
2013 Ford Escape on Landgrebe tow dolly
Mickeystamper is offline   Reply With Quote
Old 12-05-2014, 10:55 PM   #3
Iggy's Avatar
I also have a 378TS with a 244" wheel base and have the larger differential. I believe it is has a 6.17 ratio and is designed for GVWR 24,000lbs - 26,000 lbs .
The smaller one is 5.38 ration for GVWR 20,500 - 22,000 lbs
Then the really small one is 4.88 ration for GVWR of 16100 lbs - 18,000 lbs
You also have to understand what GVWR means.
Here are a few pictures of my round differential which is the biggest and has a 6.17 ration.
Now if you have the larger on it just may have been in the specs for that bare motorhome frame. Why lose any sleep over it as it is a much stronger differential.
It would be nice to see a picture of your data sticker on the wall behind the drivers seat.
This will show what you have in weight of your rig.
Also do you have 22.5" tires or the smaller ones?
ID:	67183   Click image for larger version
Old 12-05-2014, 11:47 PM   #4
Mickeystamper - I do have F5D in my VIN # and will search for the F550 brochure you posted. Thanks!
IGGY - I will take photos of the differential and the data sticker. My MH has 22.5 tires with suggested cold pressure of 100PSI.
2013 Smart Car TOAD
Old 12-06-2014, 09:13 AM   #5
Iggy's Avatar
Correction above we have a 242" wheelbase not a 244"
Old 12-06-2014, 11:44 AM   #6
Iggy Correct 242" WB not 244"
2013 GT XL 378TS
Fire Mist
Old 12-06-2014, 06:19 PM   #7
mike.t's Avatar
Should have an ID tag on the 3rd member. (I think ;o) )
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is online now   Reply With Quote
Old 12-07-2014, 11:48 AM   #8
Mickeystamper - I found your past posting with a link to the F550 brochure. Unfortunately the link no longer works. However, I found the information on the Internet. Thanks
IGGY - Attached are photos of the data sticker and differential.
ID:	67255   Click image for larger version
ID:	67256   Click image for larger version
2013 Smart Car TOAD
Old 12-07-2014, 12:27 PM   #9
Iggy's Avatar
Looks like your differential is a Dana 135.
I also noticed you have a different sway bar than I have.
Your GVW is 24,000 lbs and mine is 22,000 lbs
Would like to know what is the difference in the differentials?
Your tires bigger 255/80/22.5
Mine are 235/80/22.5
Man what do you have in your rig rocks? Your weight and tires are the difference.
You must have tile floors and residential refrigerator.
Thanks for the pics.
Your rig is 24,000 lbs and mine is 22,000 lbs
My tire pressure is 90 and your is 100
You must have tile floors and that large residential refrigerator.
It still would be interesting in finding out what is the difference in differentials.
Old 12-07-2014, 12:54 PM   #10
Yes I do have a tile floor and residential refrigerator. Actually I have two anti-sway bars, the original and a Roadmaster. I do not have a clear picture of the original at this time, but if you look at the picture below the red lines point to small visible portions of the factory installed anti-sway bar.
2013 Smart Car TOAD
axle
