Old 06-19-2012, 04:59 AM   #11
go6car's Avatar
Agreed on Progressive. Lifetime warranty too. You can get a pole mount (with lock sold separately), or a hardwired unit.
I'm getting the hardwired on our new rig before we even pick it up:
Progressive Energy Management System 240Volt / 50Amp Hardwired w/ Remote Display
go6car is offline   Reply With Quote
Old 06-19-2012, 05:44 AM   #12
fonzie's Avatar
I use the hard wired 30 amps progressive bought form Lawrence RV. Attached is their website. 50 amp portable sells for $399.00.
Ecommerce Templates - Virtual Gadgets
Fonzie
Old 06-19-2012, 11:44 AM   #13
Iggy's Avatar
I have been looking at the Progessive direct wired model EMS-LCHW50.
It is only $254.47 on sale at Camping World.
What I like it comes with a digital readout, direct wired and has the same protection, MOV's as the $360 version of Surge Guard.
It also has a life time warranty as Surge Guard has only 1 year.
Looks like Progessive direct wired one is the direction I'm going now.
Here is a link to see the EMS-LCHW50
EMS-LCHW50C
Iggy is online now   Reply With Quote
Old 06-20-2012, 04:10 AM   #14
go6car's Avatar
In case anyone is wondering (because I was when I was looking at the two 50 amp Progressives since they 'look' the same) -- The only difference between that model and the one I posted in the earlier link is the readout display being on the unit, itself, vs being separate, where you can put it elsewhere.
Being able to put the viewer wherever you want in that storage bay comes in handy to be able to easily read it in case you have limited space to install the actual unit. I was afraid once it was installed, we would have a hard time seeing the display, hence us getting that model. Anyway just some more two cents! Can't go wrong with these units, either way!
Old 06-20-2012, 08:17 AM   #15
Iggy's Avatar
I'm getting the one with the screen on the unit. The way I figure I will be plugging in and withina few minutes it will active. By that time I should have the TV cable hooked up and the water line. After it is active I really won't look at it again until I have a power failure or have to disconnect. It does have a memory to show why the unit shut down previously. I don't have it yet as the delivery date is a few weeks from Camping World and drop shipped from the manufacturer.
Old 06-20-2012, 08:44 AM   #16
Herk7769's Avatar
Why I use both, surge protection and an autotransformer.
With these power controllers, as stated, your first indication of a problem is "shutdown." While this may save you from total system failure, it won't protect your microwave or airconditioner from a low voltage brown out (due to heavy use at the park) that does not drop below the cutout voltage (typically 104 volts).
105 VAC will destroy your air conditioner compressor over time and your magnetron may become unreliable or burn out due to higher than normal current from the low voltage.
An autotransformer will boost the incoming park voltage and keep it in the safe range (at the expense of current if it needs to do that). At a pretty high end resort in Miami (the one near the Everglades) there were so many campers running their ACs 24/7 that park power when we hooked up was at 108 volts. At 108 volts, I hooked up my Franks unit and it went right into high boost and voltage to the camper went right up to a comfortable 126 volts AC and my air conditioner ran perfectly.
HAM CALLSIGN - KC3FFW
Old 06-20-2012, 09:50 AM   #17
tmmar's Avatar
I would periodically check the readout to ensure that all is good with the power. I was at a campground one summer. I plugged in the unit and turned on the power. Everythng looked good so I turned off the brekers and plugged in. Turned the breakers on and all was still good. A day or so later I went out just to take a look and the unit was flashing a low voltage code. Just then, the AC's started to pop the breakers inside the coach. Reset the breakers on the pedestal and still showed low voltage (104volts). Notified the campground and had to move sites because their electrician couldn't fix the problem right away. I believe that the unit saved me a lot of problems. Seems that I have picked up electrical problems several times that the campground didn't know about - including Fort Wilderness and Hershey High Meadow.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-06-2012, 04:47 PM   #18
Saved Again
My Progessive model EMS-LCHW50 probally saved me again last weekend. Was at a campground and noted lower then desirable voltage at 108. Talked to the park owner and checked several other sites and they were all the same. Was assured that the voltage normally goes no lower. Next afternoon the unit starts dropping out, sometime for low voltage sometimes without indication. Called Progressive and left an afterhours message asking for help with the no indication outages. About an hour later recieved a return call from a tech that suggested the unit was picking up micro flucuations that amounted to little outages that the unit was picking up and timeout cycling. During the periods of low voltage I saw voltages down to 101 volts. Of course the unit would not allow anything below 104 in. Advised the campground of the situation and on Tuesday got an e-mail stating the power company was looking for a bad transformer that was causing low voltage in the area. Fact, fiction or whatever the camper was protected and Progressive impressed me with their afterhours service.
2007 Georgetown 373
Nutmeg is offline   Reply With Quote
Old 07-06-2012, 09:30 PM   #19
Installed my Progressive EMS today. Question???
Those who have installed the EMS, there is an option to have the unit delay start for 2 minutes for the air conditioner. The factory set is 15 seconds. The instructions tell you to check with the air conditioner mfg. to determine if the AC has the delay built in.... if not remove the jumper. So..., what do I do? Can't find anything on line if the AC has the delay or not. I'm assuming my Dometic AC has the built-in delay.
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
Old 07-06-2012, 10:10 PM   #20
On my vintage (2007) Dometic the delay depended on the type of thermostat on the wall. I would check the thermostat lit. and if nothing call Dometic with your model numbers.
2007 Georgetown 373
led pad
