09-05-2013, 04:24 AM
#21
Thanks, I'll pick one up this weekend.
Michael & Donna
Little Ones Karen & Becky
2012 Georgtown 350TS
2013 Wrangler Unlimited
Couple of Harley's (When not pulling the Jeep!)
Deland, Fl
09-05-2013, 06:09 AM
#22
I suggest these GE Carbon Replace Filter 2-Pack-FXWTC at The Home Depot
or something similar that says "carbon" on the label somewhere.
Activated carbon works pretty well to remove chlorine smell and to a lesser
degree it can remove some of the plastic hose smell/taste.
Any filter will remove debris large enough to clog your flush valve.
Can you maybe remove the line and somehow aim it at a bucket or drain
and give the line a good flush?? Sounds like you've got construction
debris in your water system.
Good Luck!
Peace!
Dan & Rita D
09-05-2013, 06:41 AM
#23
Are these just standard whole house filters?
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
09-05-2013, 06:50 AM
#24
Yes they are.
Turbs
09-05-2013, 06:59 AM
#25
Originally Posted by f1100turbo
Yes they are.
Turbs
Thank you Sir
'Pa Pa's Palace'
09-05-2013, 07:37 AM
#26
Just a note to add. We removed the aerators from kitchen and bath area fawcets in our couch and both aerators had an accumulation of a very fine sand which was restricting the flow. We believe the sand like substance was from the whole house filter itself. We replaced the supplied whole house filter with a different type and no more issues. Additionally; we replaced that #6 screw in the 310 toilet flush paddle with a #10 and no more having to keep tightning it.
09-06-2013, 06:04 AM
#27
I have the opposite problem with my 2014 335 - the flush is so strong it sprays out over the bowl. Not a pleasant experience.
09-06-2013, 06:18 AM
#28
Check out this thread post #3--
http://www.forestriverforums.com/for...tml#post453097
Happy Camping!
Peace!
Dan & Rita D
09-06-2013, 07:44 AM
#29
Always Learning
X2, but only on the first flush or two once hooking up to a water source. After that, it settles down. We've just kind of accepted that it's "normal".
(And, I *do* have a Watts regulator from RV Water Filter Store.)
09-07-2013, 08:10 AM
#30
Glad I'm not alone. We've only been out twice since picking it up, and we did notice an improvement after the initial flushes. It's on the list of new vehicle "corrections" when we bring it back in; I wonder what the dealer will say about it...
09-07-2013, 09:27 AM
#31
Ours sprays hard BUT it's almost all air.
I've learned to push the pedal just a little the first time, clears the air till the next move.
2012 Georgetown 360
SHE wanted "a new motorhome"
