Old 09-05-2013, 04:24 AM   #21
Thanks, I'll pick one up this weekend.
Michael & Donna
Little Ones Karen & Becky
2012 Georgtown 350TS
2013 Wrangler Unlimited
Couple of Harley's (When not pulling the Jeep!)
Deland, Fl
Roadglider09 is offline   Reply With Quote
Old 09-05-2013, 06:09 AM   #22
KyDan's Avatar
I suggest these GE Carbon Replace Filter 2-Pack-FXWTC at The Home Depot
or something similar that says "carbon" on the label somewhere.
Activated carbon works pretty well to remove chlorine smell and to a lesser
degree it can remove some of the plastic hose smell/taste.
Any filter will remove debris large enough to clog your flush valve.
Can you maybe remove the line and somehow aim it at a bucket or drain
and give the line a good flush?? Sounds like you've got construction
debris in your water system.
Good Luck!
Peace!
Dan & Rita D
Old 09-05-2013, 06:41 AM   #23
CSMRetired's Avatar
Are these just standard whole house filters?
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 09-05-2013, 06:50 AM   #24
TURBS's Avatar
Yes they are.
Turbs
Old 09-05-2013, 06:59 AM   #25
CSMRetired's Avatar
Originally Posted by f1100turbo View Post
Yes they are.
Turbs
Thank you Sir
'Pa Pa's Palace'
Old 09-05-2013, 07:37 AM   #26
bubbles's Avatar
Just a note to add. We removed the aerators from kitchen and bath area fawcets in our couch and both aerators had an accumulation of a very fine sand which was restricting the flow. We believe the sand like substance was from the whole house filter itself. We replaced the supplied whole house filter with a different type and no more issues. Additionally; we replaced that #6 screw in the 310 toilet flush paddle with a #10 and no more having to keep tightning it.
Old 09-06-2013, 06:04 AM   #27
I have the opposite problem with my 2014 335 - the flush is so strong it sprays out over the bowl. Not a pleasant experience.
soconor is offline   Reply With Quote
Old 09-06-2013, 06:18 AM   #28
KyDan's Avatar
Check out this thread post #3--
http://www.forestriverforums.com/for...tml#post453097
Happy Camping!
Peace!
Dan & Rita D
Old 09-06-2013, 07:44 AM   #29
Always Learning
X2, but only on the first flush or two once hooking up to a water source. After that, it settles down. We've just kind of accepted that it's "normal".
(And, I *do* have a Watts regulator from RV Water Filter Store.)
Old 09-07-2013, 08:10 AM   #30
Glad I'm not alone. We've only been out twice since picking it up, and we did notice an improvement after the initial flushes. It's on the list of new vehicle "corrections" when we bring it back in; I wonder what the dealer will say about it...
Old 09-07-2013, 09:27 AM   #31
abjb's Avatar
Ours sprays hard BUT it's almost all air.
I've learned to push the pedal just a little the first time, clears the air till the next move.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
