Old 09-10-2019, 05:52 PM   #1
Dometic Awning Tie Down
I have a 2016 335DL with the Dometic power awning.
The electric awning is convenient, but does not handle wind well, anything over a strong breeze and I worry about it being damaged.
I removed the two 1/4 20 bolts (1 in each awning arm, at the top of the arm) and replaced them with a stainless steel hook. I tied a loop in two lengths of rope, hooked the loop over the stainless hooks and secure the ropes to stakes (or vehicle, picnic table, etc). I use my windshield washer handle to hook the rope over the hook.
While I still wouldn't leave the awning unattended, I've had it fully extended in some fairly heavy winds and it's done very well.
Another advantage of tying the awning down is that I use the ropes to adjust the height/slope of the awning as opposed to having to use a step to reach the adjusting knobs which don't hold well anyway.
Hope this helps a few folks....
I forgot the photo, just added it - sorry.
Cheers,
John
Name:	Awning tie down.jpg
Outtahere100 is offline   Reply With Quote
Old 09-10-2019, 09:26 PM   #2
I like that. I'm awning shy since the one on our previous Surveyor ended up on the roof covering the air con.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 31 days
mogman is offline   Reply With Quote
Old 09-10-2019, 09:35 PM   #3
If you really want to help your power awning in the wind, search the site for 'awning hold down brackets/poles'
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 09-10-2019, 09:37 PM   #4
I'm with you. Never lost one but I've seen dozen's in the CG dumpsters. If mine can't handle the wind as is...I put it away.
TheWolfPaq82 is online now   Reply With Quote
Old 09-10-2019, 10:43 PM   #5
Dodge Guy's Avatar
The power awnings are made to fold back in the wind. unlike the fixed sail of the manual awnings. they also automatically dump water in the rain. tying it down could cause the material to tear in a high wind.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is online now   Reply With Quote
Old 09-11-2019, 06:26 AM   #6
Mr. October's Avatar
Not all power awnings. Ours does not do this.
Pete Githens
Reading, PA
Formerly - 2007 Itasca Navion (Sold and gone)
2019 Georgetown GT5 31R5
Mr. October is offline   Reply With Quote
Old 09-11-2019, 06:28 AM   #7
Cheers,
John
Funny you mention this. We just Camco tie downs this week. Weíve had 5-15 mph winds all week that would have prevented us from having the awning out at all without them. It jumps around too much otherwise.Click image for larger version
ID:	214669Click image for larger version
Pete Githens
Reading, PA
Old 09-11-2019, 07:55 AM   #8
Maybe yours does......
Old 09-11-2019, 08:41 AM   #9
Dodge Guy's Avatar
Maybe not. But Iíve seen ones tied down where the wind ripped the awning material along the trailer.
Old 09-11-2019, 08:47 AM   #10
I certainly wouldnít leave mine out in wind that strong but itís nice to be able to leave it out in light winds that otherwise make it bounce and slam down. It doesnít take much wind to lift it up.
Pete Githens
Reading, PA
dometic, awning
