Old 07-15-2017, 01:48 PM   #1
Stupac7
Dometic Refrigerator Recall
Ok I looked up my refrigerator and it is a number in the expanded recall list. Can a normal person tell if the recall work has been completed?
Stupac7 is offline   Reply With Quote
Old 07-29-2017, 11:13 PM   #2
Hi I don't like that if I do 8 to 10 hours of driving and have the refrigerator
Running on gas, all day ,is there a way I can put in a inverter to run the ref.
1964chevelle is offline   Reply With Quote
Old 07-29-2017, 11:30 PM   #3
Stupac7
I know what you are talking about. I am no expert, I think it can be done.
Old 07-29-2017, 11:37 PM   #4
2012 Solera
I believe the AC heater on the refrigerator in our Solera is rated at 320 watts. Seems like you could get and hook up a 400+ watt inverter and plug the refrigerator into the inverter.
You would also need a way to turn off the inverter so the fridge would switch to gas when camping without hookups (maybe just unplug it), and possibly a way to connect the fridge directly to AC when camping with hookups (again, maybe just move the plug from the inverter to an AC outlet).
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-30-2017, 08:09 AM   #5
360true's Avatar
I suggest that you get a larger inverter like 1000 so it can easily handle the initial startup of the unit which is significantly more draw than when it is already running.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 07-30-2017, 09:41 AM   #6
2012 Solera
Assuming it is an absorption refrigerator like the one in our Solera, the 120 volt electric operation is an electric heater (instead of the gas flame) to heat the ammonia mixture in the cooling loop. Unlike a freon compressor based refrigerator, no inductive load so no initial current surge.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-30-2017, 10:50 AM   #7
Ok but what batteries do I hook it up to ? Can I come off the coach batteries ? it won't interfere with the charger ? Is it more cost-effective to change the refrigerator to a three-way ? Going to be in N Y and you can't run with gas on!
Old 07-30-2017, 11:09 AM   #8
2012 Solera
I would hook the inverter to the coach batteries. Just an inverter - not an inverter/charger - so just another load. No interaction other than increased load with the charge circuits.
I have not done this mod, but I do have a 400 watt "pure sine wave" inverter connected to my coach batteries. Use it to recharge e-bike batteries, run my wife's "Magic Bullet" food processor, operate my wife's heating pad (bad back), run a soldering iron if needed, etc. Works great.
Not aware of any state not allowing driving with propane on. A couple of tunnels and the Alaska ferry system do require propane off. I found on the Alaska ferry my refrigerator maintained cold quite well for 12+ hours (door not opened, RV on car deck so no sun). I just turn mine off when necessary- for instance, while staying overnight in a friend's driveway where I can't level. Seems to hold cold overnight without issue.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-30-2017, 11:25 AM   #9
SecretSquirrel's Avatar
Are you concerned with amount of gas usage or just running with gas on? Fridge uses very little gas. The flame is only about an inch or so wide.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 07-30-2017, 11:36 AM   #10
2012 Solera
With regard to cost, as the refrigerator heater is a resistive load, I believe a modified sine wave inverter should work, like:
https://www.amazon.com/BESTEK-Power-...+wave+inverter
Quite inexpensive. I did run into a surprise using a modified sine wave inverter - my wife's heating pad did not work - controller issue. I switched to a pure sine wave for that reason:
https://www.amazon.com/Wagan-EL2601-...pure+sine+wave
Seems like pure sine wave inverters have been dropping in price.
As I said, I have not done this mod. If you do it, let us know how it works!
FYI
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-30-2017, 11:48 AM   #11
Can't run with gas on in New York
Old 07-30-2017, 01:57 PM   #12
Ok stupid question where can I find recall info?
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 07-31-2017, 01:15 PM   #13
Stupac7
This is where I went to find out.
http://67.238.126.140/
dometic, recall, refrigerator
