Old 04-02-2012, 06:39 PM   #1
2012 Georgetown 378
raycyn778's Avatar
Dometic RM1350 WID Fridge ignition lock
Hello, everyone, I have been going back and forth with my dealer and now FR about the ignition lock on the Dometic fridge. Dometic says that there is no reason that it should NOT be wired up and FR says that they do not hook it up at the factory. When asked why not, they have no answer except to say that it is not a safety issue. Does anyone have this feature working in their unit? Simply put, the fridge locks automatically when the ignition for the engine is turned on. Sounds like a great feature so why not connect it??
Ray, Cynthia, Duncan and Bailey
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
raycyn778 is offline   Reply With Quote
Old 04-02-2012, 06:46 PM   #2
TURBS's Avatar
we need want ours on when traveling thats why mine wouldnt be hooked up if there was such a thing on mine.
I wouldn't want it locked other than maybe the door not to open.
Old 04-02-2012, 06:50 PM   #3
sherdep's Avatar
I am with F1100turbo on this one
I like the fact that I can run my fridge when I am traveling - I hate the idea of putting food in a cooler and then having to wait for the fridge to cool down before I can put my food in it or run the risk of food spoiling if in a fridge that isnt on.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-02-2012, 07:05 PM   #4
2012 Georgetown 378
raycyn778's Avatar
I should have explained it better...the lock does nothing other than lock the doors when you start up the coach..great if you forgot to manually lock it before you leave. you can unlock it manually while your in motion if you want to get in it. Does not in any way interfere with it's operation
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
Old 04-02-2012, 07:22 PM   #5
sherdep's Avatar
I wouldnt think it would be all that hard to hook it up - just needs to be on a 12v source that is switched with the ignition.
and I apologize for jumping in - I thought the same thing about the fridge not operating when in motion - didnt realize it was for the locking of the doors only
Old 04-02-2012, 07:59 PM   #6
Hi ! raycyn
My battery compartment cover, when flipped over has a schematic of the Forest River Battery Control Center wiring. If you have this schematic you will see that fuse position #4 is used for the frig door lock. If this is valid then check this fuse position for both a blown fuse and wiring.
If you do not have this drawing I will send you a copy.
mbtelguy is offline   Reply With Quote
Old 04-02-2012, 08:06 PM   #7
sherdep's Avatar
Originally Posted by mbtelguy View Post
Hi ! raycyn
if it is in PDF you can also post it to the thread as well
Old 04-03-2012, 11:25 AM   #8
2012 Georgetown 378
raycyn778's Avatar
Hi ! raycyn
Thanks, I will check for it today as I keep my coach in an off site lot. HOA does not allow us to keep any type of trailer ,RV etc. on our lots.
Here is what I have a problem with, after spending almost an hour on the phone with FR, they admit that they do NOT hook it up "on gas units" and can not explain why!! I called Dometic and they say there is no reason they know off NOT to hook it up. If it is already wired for it, why wouldn't FR hook it up??!!!
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
Old 04-03-2012, 12:33 PM   #9
TURBS's Avatar
I reread your post and now see what your talking about.
but what I don't understand is why you so passionate on getting
It hooked up or are worried about it?
My doors in 10 years have never opened while traveling.
just wondering is all.
Old 04-03-2012, 01:08 PM   #10
2012 Georgetown 378
raycyn778's Avatar
We have only had this coach for a few months..a couple of trips ago, a quart of milk flew out of one of the doors while we were moving and spilled all over the floor and down into the floor heat vents..it's use is explained in the owners manual and it is set up to do it.. so why isn't it?
If your unit had A/C but it wasn't hooked up.....if you had auto retracted steps but weren't hooked up....if it had power shades but wasn't hooked up....
a
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
