Old 06-26-2016, 11:17 AM   #11
Originally Posted by Modmike View Post
I used to have a 320 in my other rig and considering swapping out my 310. The 320 had a rim that prevented sloshing while travelling and was also more comfortable.
What was interesting is that the extra space it took was towards the rear of the toilet so it sat closer to the wall and didn't take up any valuable space.
I'm not big fan of the 310 comfort or the value its vaunted "swirl" technology. Any reason to keep the 310 over the 320?
I swapped for the 320. Actual adult toilet just like at home, bigger bowl area at top. You can put any seat on it and I installed one of those seats that don't slam when you close it, nice late at night...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 06-26-2016, 01:11 PM   #12
mcmartinez's Avatar
If you have a Dometic 300 take a look at this article. There is a defect and dometic will replace it with a 310 o 320 model.
Amazon.com: TPerk100's review of Dometic 300 Series Standard Height Toilet,...
Mario Martinez
2703WS Rockwood Super Lite (6,400 Dry weight)
Tow Vehicle - 2010 Ford F-150 Super Crew
5.4L V-8 6-spd auto 2x2 9,800 Lbs. towing capacity.
mcmartinez is offline   Reply With Quote
Old 06-26-2016, 01:37 PM   #13
Also, some silicone plumbers grease works on the seal wonders.
AbdRahim is offline   Reply With Quote
