Old 06-25-2016, 10:25 PM   #1
Dometic toilet help needed
I have a domestic 310 toilet that came standard in my 2016 364.
We are currently in our 4th trip out and last night, it stopped holding water all off a sudden.
I did all the common things:
1. Brushed the underside of the seal
2. Poured very hot water in the bowl
3. Let the ball close hard by slipping foot of the pedal
4. Drizzled some olive oil on the seal
5. Used a gloved finger to push seal down
Nothing worked. Is it at all
Possible for a seal to suddenly fail in the space of one hour? Anything else I can try? The smell
Is unbearable.
Thanks.
Modmike is offline   Reply With Quote
Old 06-26-2016, 06:26 AM   #2
bubbles's Avatar
That's the way it happens sometimes. If there is a gap between the ball and seal one side of the ball valve may have popped out of its pivot hole down one side below the valve. If so just reach thru opening and pop back in.
Old 06-26-2016, 07:27 AM   #3
Mr. Dan's Avatar
X2
BTW, if you do a search for answers, spell the word DOMETIC as I have altered the thread title.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 06-26-2016, 08:07 AM   #4
I know how it's spelled but phone decided to correct it and I didn't catch it. I also know how to search, that's how I got the suggestions listed in my first post.
Ball valve issue makes sense.
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Old 06-26-2016, 08:30 AM   #5
AquaMan's Avatar
I've also heard that lack of water pressure has not put enough pressure on the seal and has allowed water to seep through. Not sure if I buy it though.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 06-26-2016, 09:05 AM   #6
I just bought a new 310 and out of the box it leaked. Did the hot water trick and it quit leaking. The only thing I did different was to fill the bowl completely to add a little more pressure. Also, you need to leave the water in the bowl until it completely cools so the seal sets.
latner is offline   Reply With Quote
Old 06-26-2016, 10:38 AM   #7
That was it. I thought the ball was sitting low. Covered my hand with a plastic bag, reached in, and reset it. Works perfect now.
Didn't find that tip anywhere, thanks!
Old 06-26-2016, 10:39 AM   #8
Me neither, has nothing to do with pressure.
Old 06-26-2016, 10:45 AM   #9
Ford Idaho's Avatar
Glad you were able to get it working and thank you for posting the fix.
Old 06-26-2016, 10:45 AM   #10
I used to have a 320 in my other rig and considering swapping out my 310. The 320 had a rim that prevented sloshing while travelling and was also more comfortable.
What was interesting is that the extra space it took was towards the rear of the toilet so it sat closer to the wall and didn't take up any valuable space.
I'm not big fan of the 310 comfort or the value its vaunted "swirl" technology. Any reason to keep the 310 over the 320?
