Old 12-16-2014, 04:09 PM   #1
Door Gas Strut Bracket
OK folks...the bracket on the top of the door for the gas strut has broken loose from the door. It was only pop riveted into place and now has pulled loose and is allowing the door to open wide enough so it is hitting the edge of the slide for the living room. Anybody else had this problem and what is the solution? I thought about drilling out the pop rivets and putting sheet metal screws in but the material is so flimsy that I don't think it will last. Maybe just remove the gas strut and figure out a way to keep the door from hitting the slide edge when open. Looking for some ideas!
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 12-16-2014, 05:45 PM   #2
Senior Member - Retired
Information in the following discussions may help:
Main Door Cylinder Bracket
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
Old 12-16-2014, 06:28 PM   #3
Drill the pop rivets out and re-rivet it with 3/16" dia rivets and make sure the head is on the door and not on the bracket. You might even add a 3rd rivet.
door, gas
