Old 11-14-2014, 09:20 AM   #1
Double D - 2014 Georgetown XL
Cold weather has arrived leaving shortly for south. Turned on furnace, the only heat seems to come from vents in kitchen near floor.
Am I missing something? Ceiling vents only blow cold air, no heat in bathroom or bedroom.....Please help Doug
double D is offline   Reply With Quote
Old 11-14-2014, 09:53 AM   #2
chrisbailey13's Avatar
The furnace only blows from the lower vents. if the ceiling vents are blowing also, you need to switch your fan from HI/Lo to Au.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 11-14-2014, 09:57 AM   #3
Also, if you have a 352, 377 or 378, there are two furnaces, so you need to turn the furnace on at both thermostats.
Old 11-14-2014, 09:59 AM   #4
kenandterry's Avatar
Maybe things have changed between our rig and the newer ones........
The floor vents in ours are for heat only..........the ceiling vents are for fan or air conditioning only. We don't have a heat pump on our rig.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-14-2014, 10:25 AM   #5
Just tried thermostats. How do I get aux. position? All the buttons are fan,cool, furnace, and the other side is plus and minus for temp. The bottom button selects fan,cool and furnace, but I see no aux. ?
Old 11-14-2014, 10:28 AM   #6
Select the Fan, on the plus/minus temp side press up or down until the display says Au which stands for Automatic.
once selected, switch the thermostat to Furnace. only the furnace should come on. not the overhead unit. if you have 2 furnaces you will have to do this at both thermostats.
Old 11-14-2014, 12:31 PM   #7
Thanks to all who supplied info. Great help. Leaving tonight wife doesn't,t like cold thanks again.
2014, georgetown
