Old 11-10-2015, 10:08 PM   #11
Vince and Charlette's Avatar
I too have a 2015 GT 364TS. It has three drain lines wrapped together right behind the right rear tires: two blue and one red . The red and one of the blues respectively are the hot and cold low point drains. The other blue is the fresh water holding tank drain. (Don't confuse this with the clear plastic fresh water overflow line.) Once you find it, I recommend adding a simple 90 degree hand valve (at Lowes) to make opening and closing the drain very easy thereby avoiding the "water in the face" actuation.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 11-11-2015, 08:13 PM   #12
These are drains for water lines and water pump for wnter servicing, There should be a separate valve for draining the tank, min os o the left front corner.
Jim G is offline   Reply With Quote
water tank, water, drain, fresh water, tank
