Old 11-09-2015, 01:43 PM   #1
rxrdbou1969's Avatar
Draining fresh water tank
Attempted to drain fresh water tank from low point drains and can't get any water to flow unless I turn water pump on. This started only after I completely filled tank and it overflowed from vent. Before, I would only partially fill tank and it drained fine. I tried turning on all water taps inside coach and had plugs out of heaters but water flowed only after I would turn pump on. Any thoughts? Forgot to say but I have a 2015 Georgetown 364TS.
rxrdbou1969 is offline   Reply With Quote
Old 11-09-2015, 01:48 PM   #2
Just A Member
EDABEUT's Avatar
You have water in the vent hose and it cannot vent. Try blowing air into the vent at your water tank fill outlet to clear out water then try to drain it again.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 11-09-2015, 02:15 PM   #3
Flybob's Avatar
You should have two ( one red and one Blue/white) low point drains. These drain the plumbing in your unit. You should also have a fresh water drain near your FW tank. You need to use the Fresh Water drain to drain the FW tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-09-2015, 02:27 PM   #4
I opened the red and blue which are near edge of motorhome behind right side dual rear wheel. Side of coach indicates these are fresh water drains. Have no other drains near fresh water tank.
Old 11-09-2015, 02:41 PM   #5
Flybob's Avatar
The red and blue drains drain the plumbing ( red hot side, blue cold side) and not the FW tank drain. Not sure where the FW drain is on your unit, but that is what you need to drain the FW tank.
TST Tire Monitors
2 100W solar panels
Old 11-09-2015, 04:43 PM   #6
RVnut's Avatar
This is what I have on my 364 that I picked up Monday.. Does yours look like this.. Now mine has the two water heaters and two pumps
Name:	tank drain 001.jpg
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 11-10-2015, 11:57 AM   #7
Draining
Not sure you could drain the FWT through the low points. This would have to siphon the water from the tank through the pump and I don't think that will work. Makes sense that water only comes out of low points when the pump is on. Find the drain tube by the FWT and drain from there.
Reason201 is offline   Reply With Quote
Old 11-10-2015, 12:07 PM   #8
chrisbailey13's Avatar
It looks like the two blue lines that are together might be your low point drains for the FWT. you should be able to see which tubes are connected to the FWT by looking at the bottom of the tank in the compartment.
BTW, I have never had to run the pump to drain the FWT.
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 11-10-2015, 12:43 PM   #9
Air Force Retiree
FWT Drain
On my 2014 3050 Behind the panel ,in the storage area, just after the pump, I have a shutoff that drains the FWT.
While on this subject, has anyone installed a winterizing pump kit on a 3050?
Retired Air Force is offline   Reply With Quote
Old 11-10-2015, 12:49 PM   #10
I have similar situation at my Prism 24G.
Fill up Fwt (2/3) open all faucets and turn on water pump for about 10 minutes and no water out.
Help me out,
please
Prism 24G is offline   Reply With Quote
water tank, water, drain, fresh water, tank
