11-09-2015, 02:43 PM
Draining fresh water tank
Attempted to drain fresh water tank from low point drains and can't get any water to flow unless I turn water pump on. This started only after I completely filled tank and it overflowed from vent. Before, I would only partially fill tank and it drained fine. I tried turning on all water taps inside coach and had plugs out of heaters but water flowed only after I would turn pump on. Any thoughts? Forgot to say but I have a 2015 Georgetown 364TS.
11-09-2015, 02:48 PM
Just A Member
You have water in the vent hose and it cannot vent. Try blowing air into the vent at your water tank fill outlet to clear out water then try to drain it again.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
11-09-2015, 03:15 PM
You should have two ( one red and one Blue/white) low point drains. These drain the plumbing in your unit. You should also have a fresh water drain near your FW tank. You need to use the Fresh Water drain to drain the FW tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-09-2015, 03:27 PM
I opened the red and blue which are near edge of motorhome behind right side dual rear wheel. Side of coach indicates these are fresh water drains. Have no other drains near fresh water tank.
11-09-2015, 03:41 PM
The red and blue drains drain the plumbing ( red hot side, blue cold side) and not the FW tank drain. Not sure where the FW drain is on your unit, but that is what you need to drain the FW tank.
TST Tire Monitors
2 100W solar panels
11-09-2015, 05:43 PM
This is what I have on my 364 that I picked up Monday.. Does yours look like this.. Now mine has the two water heaters and two pumps
364 Georgetown 2016
in Montana
11-10-2015, 12:57 PM
Draining
Not sure you could drain the FWT through the low points. This would have to siphon the water from the tank through the pump and I don't think that will work. Makes sense that water only comes out of low points when the pump is on. Find the drain tube by the FWT and drain from there.
11-10-2015, 01:07 PM
It looks like the two blue lines that are together might be your low point drains for the FWT. you should be able to see which tubes are connected to the FWT by looking at the bottom of the tank in the compartment.
BTW, I have never had to run the pump to drain the FWT.
2014 Georgetown XL 352QS
2013-2019 Days Camped-502
11-10-2015, 01:43 PM
Air Force Retiree
FWT Drain
On my 2014 3050 Behind the panel ,in the storage area, just after the pump, I have a shutoff that drains the FWT.
While on this subject, has anyone installed a winterizing pump kit on a 3050?
11-10-2015, 01:49 PM
I have similar situation at my Prism 24G.
Fill up Fwt (2/3) open all faucets and turn on water pump for about 10 minutes and no water out.
Help me out,
please
11-10-2015, 11:08 PM
I too have a 2015 GT 364TS. It has three drain lines wrapped together right behind the right rear tires: two blue and one red . The red and one of the blues respectively are the hot and cold low point drains. The other blue is the fresh water holding tank drain. (Don't confuse this with the clear plastic fresh water overflow line.) Once you find it, I recommend adding a simple 90 degree hand valve (at Lowes) to make opening and closing the drain very easy thereby avoiding the "water in the face" actuation.
2018 Berkshire 38A
11-11-2015, 09:13 PM
These are drains for water lines and water pump for wnter servicing, There should be a separate valve for draining the tank, min os o the left front corner.
