Old 06-20-2014, 03:21 PM   #1
Draining the fresh water tank
Never mind I found it....duh
bmurph44 is offline   Reply With Quote
Old 06-20-2014, 05:58 PM   #2
Cornelius's Avatar
Just in case someone reads this who didn't find it, there is a plastic valve located underneath the compartment that contains the fresh water tank. The valve is located next to the tank overflow vent tube outlet.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 06-20-2014, 08:36 PM   #3
I was looking under the wrong side, if I'd just looked for the low point drain decal on the storage doors I'd have seen it right away. Mine have the tubes hanging with threaded plastic plugs for the drain. Still getting to know my new to me coach.
Old 06-21-2014, 11:07 AM   #4
On my coach they painted over the low point drain stocker so talk about confused
fullenw is offline   Reply With Quote
Old 06-21-2014, 11:26 AM   #5
mark0224's Avatar
Found mine can spin it around in circles and no water comes out any ideas. Or how do you replace it with pex tubing
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-21-2014, 11:40 AM   #6
Ford Idaho's Avatar
The valve spins?
You want to replace the down tube or?
Old 06-21-2014, 11:45 AM   #7
Are you draining the fresh water tank through the low point drain, or am I missing something. The fresh water tank should have it own valve for draining.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-21-2014, 02:03 PM   #8
tncruiser's Avatar
mine did i replaced them with valves a lot easier to use
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 06-21-2014, 11:32 PM   #9
mark0224's Avatar
What I was trying to say was my valve on the fresh water drain and the low point drain just turn around 360 degrees and no water comes out. Due to the fact that all the plumbing is pex tube and the valve is in between two pieces of pex tube how do you remove the existing valve and put in a new one.
Old 06-22-2014, 05:48 AM   #10
DarrenK's Avatar
Pex valves are push-pull...I don't remember which is on or off, but they will spin freely....
DarrenK is offline   Reply With Quote
Old 06-22-2014, 08:14 AM   #11
mark0224's Avatar
Ok wasn't told that by tec during walk through thanks, didn't want to try pulling it and break it then trying to cob up something that might not work
Old 06-22-2014, 08:19 AM   #12
Ford Idaho's Avatar
If something does happen you can just go to Home Depot or Lowes and buy the Shark Pex fittings and what ever 1/2 inch valve or cap you want.
Old 06-22-2014, 10:49 AM   #13
brianj
Can you tell me what kind you used or maybe a picture?
Thanks!
Old 06-23-2014, 08:56 PM   #14
Thanks!
brianj
Can anybody else tell me what kind of valve tncruiser may have used, was it plastic?
drain, fresh water, tank, water, water tank
