Old 01-06-2015, 06:03 PM   #1
Drip from hose at heater core
Anyone have this problem? Wondering if it is just the hose connection or maybe something inside the heater core? Smells like anti-freeze.
MattM is offline   Reply With Quote
Old 01-06-2015, 06:13 PM   #2
Tim & Lisa Trempert
You have a leak you should not have. Antifreeze is slippery between your fingers. You likely need a new hose or a new core. Not worth risking overheating your engine. Hopefully it's just a hose or loose clamp. You should be able to get a flashlight just after you've run the engine up to temperature (so there is pressure in the hose) and dab dry with a rag while looking for the source.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 01-06-2015, 06:19 PM   #3
Ford Idaho's Avatar
The clamp may look like this.
If so remove it and replace it with one like this.
Top off the antifreeze and check for leaks.
Old 01-06-2015, 06:35 PM   #4
thanks. two hoses attached to side of heater with the leak coming from the upper. Not sure if it's coming out of the hose connection or from inside the covering of the core. Will take it in for sure.
Old 01-06-2015, 06:43 PM   #5
Ford Idaho's Avatar
Odds are if it is leaking from the top it is the clamp as a bad core would leak from the bottom before filling the housing full enough to leak from the top.
Old 01-06-2015, 06:53 PM   #6
Crusadernoob's Avatar
What type vehicle?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 12
Crusadernoob is offline   Reply With Quote
Old 01-06-2015, 10:44 PM   #7
Ford V-10 but the heater core looks aftermarket...probably the usual Lippert made in China crap.
heater
