09-24-2016, 04:18 PM
WI Sports Nut
Driver Side Chair Turn Around?
I cannot get my driver side chair to turn around completely. It hits the steering wheel. I move it all the way back with the power controls, but it won't turn around. What am I missing lol?
NEVERMIND! I searched the forum and found the answer elsewhere! Chair turned around!
2011 Forest River Georgetown 378TS
Hales Corners, WI
09-25-2016, 09:41 PM
Everyone says thanks
Anytime. That was the easiest answer i have ever given.
Just kidding had the same problem myself
2011 Gergetown 378 TS XL on a Workhorse W22 chassis
Toad is a 2014 Chevy Cruze RS
09-26-2016, 04:31 PM
What is the solution? I have the same problem. It only turns 90 degrees an hits the wheel.
09-26-2016, 06:31 PM
Here's how I did it.
Tilt steering wheel all the way forward.
Move the chair all the way back.
Do not raise arm rest, keep it in the lowered position.
The chair back must be tilted forward all the way.
Turn chair clockwise
My coach is a 2013 378 XL
If needed I will take pictures
2013 Georgetown XL 378
2008 Honda CR-V
09-26-2016, 07:11 PM
Thanks wrapperman, I will try that soon. Mine is also a 2013 378xl TS
09-26-2016, 07:33 PM
One change
Move the chair all the way forward not all the way back.
It rubs fairly hard just use your fingers to push in the foam as it is trying to get passed the steering wheel. At first i was scared i would break or rip something but it won't.
09-26-2016, 07:52 PM
I stand corrected. Thanks Moorio. I should never write from memory.
I just checked it out.
Tilt chair forward.
Move chair 3/4 the way forward.
Then turn.
It may even help to start turning the chair when it is 1/2 the way forward then as you turn slide the chair move it forward 3/4 of the way.
After you do it one time it is really easy.
2008 Honda CR-V
09-27-2016, 01:25 PM
Kanadian Kamper
The plate of the pedestal which is mounted to the floor of the Georgetown, is NOT in the same position for all Georgetowns.
It is positioned arbitrarily by someone in the assembly area.
I guarantee that others (along with myself) CANNOT turn the driver's seat all the way around by using ANY of your tips for doing so.
Any other Georgetown owners out there that can't do the turn around?
I'm not trying to be a threadkiller either.
Ken and Terry
09-27-2016, 01:39 PM
you may be right
That is a good point. Mine is on a Workhorse chassis and maybe the steering columns are different from year to year and Ford vs Chevy. Yes that would be nice to see if anyone else can't get theirs turned around.
09-27-2016, 02:07 PM
Kanadian Kamper
I thought most Georgetowns were based in the Ford F53 chassis.
But, the worst case scenario I read on one of these forums (maybe not Forest River) was an owner that could turn his seat around, HOWEVER.....his steering wheel was NOT directly dead centre of his driving seat.
Others have reported their seat cannot be moved far enough forward (if they're short in the legs) or far enough rearward (if they're long in the legs)
My driver's seat only turns a few inches past 90 degrees towards the interior, and the most comfortable position has the left arm rest in the up position and I use the steering wheel as my left arm rest.
Just gotta be careful not to honk the horn.
Ken and Terry
09-27-2016, 02:15 PM
Especially if you always keep the switch toggled to Air
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
09-27-2016, 02:39 PM
If you will notice, the driver's seat in a Georgetown class A is directly behind the steering wheel, the passenger seat, however, is mounted much closer to the outside wall so as to create more space between the two.
I have seen a stripped chassis before assembly and generally the 4 bolts for the driver's seat are already installed by the vendor.
2015 335DS
09-29-2016, 11:17 AM
Georgia Gets Around
Just wanted to chime in and say that in turning our captains chair we somehow dislodged the power seat wires. I say we but it was probably me anyhow just a warning - we got it fixed at the rally.
2015 Georgetown XL 369
2005 Jetta TDI
09-30-2016, 03:06 PM
On my 2015 GT 364, I found that after turning the driver's chair around, I could activate the slide release bar again and move the chair even further back than I could if it were facing forward.
2018 Berkshire 38A
