Old 10-03-2014, 08:35 PM   #11
VinceU's Avatar
Originally Posted by rwehba View Post
Just got home from a 1800 mile vacation to Colorado and Grand Canyon "wow" but the drivers chair is 3-3/8" to the right of center of steering wheel it just don't feel right to sit and hold wheel like this is this right or did someone really mess up on installing it.
I corrected a very severe tilt problem with the seat/steering wheel geometry. They used stove bolts under the carpet with lock nuts underneath. Works out they are easy to remove and move over by predrilling once the new area is selected. Only problem wanna restrict the amount of movement as the carpet on the floor is cut to the present position. Again no bolt heads on floor only outside. You must temp cut carpet to the get the bolts out.
Old 10-10-2014, 01:18 AM   #12
vakeel's Avatar
Originally Posted by GABoy View Post
My driver chair is situated just fine. My gripe is passenger chair. It is mounted closer to wall than drivers side and causes it to not swivel around like it should for use when parked. The arm of chair hits the wall. Looks like it needs to go over at least 2". Anyone tackled this or have same issue?
I have not tried this in a while so I may be getting it wrong, but if I remember correctly we have to fold the back portion of the seat all the way forward towards the windshield and then the chair swivels fine without hitting the side when you swivel it either clockwise or counterclosckwise [sorry, can't remember which way] and not quite as easily the when you swivel the other way. Hope this helps rather than hurts.
2013 Georgetown XL 377TS
vakeel is offline   Reply With Quote
Old 10-18-2014, 01:53 PM   #13
gmann55's Avatar
I have a 2008 370 Georgetown. My drivers seat will only turn 90 degrees and face the passengers seat. I cannot get it to turn to face the back of the motohome. It hits the steering wheel.Can anyone get there's to turn around 180 degrees?
gmann55 is offline   Reply With Quote
Old 10-18-2014, 04:14 PM   #14
DarrenK's Avatar
Here's a thread about swiveling the seats:
Front seat swivel - 351ds?
DarrenK is offline   Reply With Quote
Old 10-18-2014, 07:41 PM   #15
I can swivel mine ..Driver-side.. I just push the seat back as far as it will go, tilt wheel up, bring seat back forward and rotate seat.. ... For passenger seat..I just lean seat back forward..and rotate seat..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 10-18-2014, 09:12 PM   #16
360true's Avatar
My 2014 378 driver seat does not swivel. Have tried all of the methods. Dealers says it is a factory design issue. Passenger seat swivels but when facing back is only a 1|4 inch from the wall not enough for comfortable seating. No elbow room.
360true is offline   Reply With Quote
