09-28-2014, 12:04 PM
Drivers chair
Just got home from a 1800 mile vacation to Colorado and Grand Canyon "wow" but the drivers chair is 3-3/8" to the right of center of steering wheel it just don't feel right to sit and hold wheel like this is this right or did someone really mess up on installing it.
09-29-2014, 08:53 AM
Well no comments so I,ll ask can the drivers chair be moved over I know it will not swivel then but I would like it centered if possible
09-29-2014, 10:36 AM
I would suggest going to your dealer, or any dealer really, and try sitting in some of their GTs. If they feel more centered then see if they can fix yours.
Joel K
2013 Coachman Mirada 29DSSE
09-29-2014, 01:34 PM
Mine is definitely off center in regards to the steering wheel, but not uncomfortably so...
09-29-2014, 02:34 PM
rw, can you look under the chair at the mounting bracket to see if it has holes for the bolts or are they slots? If slots you should be able to move it.
2013 Berkshire 390BH
09-29-2014, 06:42 PM
Nope no slots think ill. Have one of our welders do a offset on the pedestal
10-02-2014, 07:04 PM
My 2007 Georgetown has the same problem. The drivers seat is off center by about an inch and half. I was told that I would need to drill new holes through the floor and move the seat over. I have not done that, I sit to one side of the seat and drive like that.
Poor quality workmanship.
10-03-2014, 08:39 AM
My driver chair is situated just fine. My gripe is passenger chair. It is mounted closer to wall than drivers side and causes it to not swivel around like it should for use when parked. The arm of chair hits the wall. Looks like it needs to go over at least 2". Anyone tackled this or have same issue?
2014 Georgetown 351DS
Chevy Colorado Crew
10-03-2014, 04:06 PM
You could elongate the holes on the mounting plate were it attaches to floor as well as were seat bolts to..(.an inch on both gives you two inches of play to move it around)
2010 Georgetown 300FWSSouth Florida
10-03-2014, 07:58 PM
Retired Ford Tech
Our 2008 350sets had the same problem with the passenger seat. I got a piece of 1/4 aluminum plate and placed it in the original holes, the measured 5 inches over and used 2 of the original pedastal holes and drilled 2 more in the ped. Through the floor with a total of six bolts. Works like a charm and we have room for more stuff next to the seat.
10-03-2014, 08:35 PM
I corrected a very severe tilt problem with the seat/steering wheel geometry. They used stove bolts under the carpet with lock nuts underneath. Works out they are easy to remove and move over by predrilling once the new area is selected. Only problem wanna restrict the amount of movement as the carpet on the floor is cut to the present position. Again no bolt heads on floor only outside. You must temp cut carpet to the get the bolts out.
10-10-2014, 01:18 AM
I have not tried this in a while so I may be getting it wrong, but if I remember correctly we have to fold the back portion of the seat all the way forward towards the windshield and then the chair swivels fine without hitting the side when you swivel it either clockwise or counterclosckwise [sorry, can't remember which way] and not quite as easily the when you swivel the other way. Hope this helps rather than hurts.
2013 Georgetown XL 377TS
10-18-2014, 01:53 PM
I have a 2008 370 Georgetown. My drivers seat will only turn 90 degrees and face the passengers seat. I cannot get it to turn to face the back of the motohome. It hits the steering wheel.Can anyone get there's to turn around 180 degrees?
10-18-2014, 04:14 PM
10-18-2014, 07:41 PM
I can swivel mine ..Driver-side.. I just push the seat back as far as it will go, tilt wheel up, bring seat back forward and rotate seat.. ... For passenger seat..I just lean seat back forward..and rotate seat..
10-18-2014, 09:12 PM
My 2014 378 driver seat does not swivel. Have tried all of the methods. Dealers says it is a factory design issue. Passenger seat swivels but when facing back is only a 1|4 inch from the wall not enough for comfortable seating. No elbow room.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
