Old 09-19-2015, 05:32 PM   #1
Droopy Jack
One of my jack has started to extend. Whenever I check on the m/h when it's sat with jacks retracted ( in storage) for some time it 's come down on it's own . Once I start m/h up and turn on leveling system I can get it to retract but I'm concerned that this is the beginning of something more serious. Has anyone run across this ?
Nomore9-5 is offline   Reply With Quote
Old 09-19-2015, 06:51 PM   #2
bend302's Avatar
Yep. Mine has done that (dropped down in storage). A couple of times. I now have a check jack note on the steering wheel.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-20-2015, 07:08 PM   #3
chrisbailey13's Avatar
Mine does the same thing when it sits more than a few days. but as soon as I start the RV, the jack retracts.
2014 Georgetown XL 352QS
2013-2019 Days Camped-490
chrisbailey13 is offline   Reply With Quote
Old 09-22-2015, 09:53 AM   #4
Fireman
Send a message via AIM to dutch
jacks
Mine has done that since we brought home new. must be that all off them do that.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
Old 09-22-2015, 11:39 AM   #5
Iggy's Avatar
If you turn off all your batteries when in storage and this happens some of the isssues that may cause this are:
1. One of the levelers control valves are leaking and releasing the pressure slowly back to the tank. It also may be the pressure relief valve not sensing and maintaining pressure to hold things up. (battery power must be on for this to happen)
2. You may have a hose that has bubbles on the exterior and a small pin hole that releases the fluid which could make that leveler drop a small amount.
If this happens only to a particular leveler I would look closely to the hoses, fittings and that control valve.
3. It also may be a seal around the shaft of the leveler that drops.
4. If the tank level is lower than it should be also may cause a drop in pressure.
I would do a close inspection to see if you have any oil buildup around which would indicate a small leak.
Hope this helps you find the issue that you may have. I'm sure others may have similar problems but its not normal and the cause need to be found and corrected.
Good luck.
2012 Georgetown XL - 378TS 63K + miles
Old 09-22-2015, 12:06 PM   #6
Droopy Jack
Iggy, my thanks for taking the time to list possible causes. I'll make a note of these and have a look.
roo
