Old 11-20-2013, 07:49 PM   #1
Dummy Me!
I didn't do the purge procedure on our residential fridge because we are leaving for FL this Friday. With a full tank of LP gas I left the heater on at 60 degrees. I went out today to put some stuff in the coach and it was colder in the coach than it was outside. The temperature inside the refrigerator was 32. I went through an entire tank of LP gas in a couple of weeks. I went out and bought one of the oil filled heaters to bring the temps up, but I can only hope the water lines did not bust in the refrigerator as it was the only thing that was not winterized.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 11-20-2013, 08:08 PM   #2
TURBS's Avatar
A camper furnace is a gas hog as you found out.
A twenty pound pig doesn't last long.
I would be surprised if you got a week out of a 20 lb pig.
TURBS
Old 11-20-2013, 08:31 PM   #3
What is the Propane Capacity? 60-80 Gal? Youroo!! This is for the Georgetown>
Old 11-20-2013, 08:37 PM   #4
Mine is only 24.5 gal propane.
