Old 07-10-2015, 12:01 PM   #1
CalifRvLawyer's Avatar
Effective Way to seal compartment doors?
On of the compartments where the inverter is located is not well sealed, and water gets in, and the RV almost cut fire once. I am trying to find out the best way to seal it.
There is a seal, but obviously is not working well and I have to find a better solutions.
Any suggestions?
Tony
CalifRvLawyer is offline   Reply With Quote
Old 07-10-2015, 03:49 PM   #2
I thought you needed air around the invertor to keep it from over heating and burning up.
Iggy is offline   Reply With Quote
Old 07-10-2015, 04:07 PM   #3
I made a small round hole on the site of the compartment to help air circulate, and I will probably put a small fan. But as for the seals around the compartment door, I need to make sure water (from water sprinklers or any water directed at the RV) won't penetrate it.
Old 07-10-2015, 04:50 PM   #4
Here is a great link if you need to replace or add seals almost any wher eon a trailer or motorhome.
https://www.factoryrvsurplus.com/cat...ategory_id=170
Old 07-10-2015, 06:34 PM   #5
If you are having problems with the door seals they are adjustable to make a tighter seal.
You should not have any water issues.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 07-10-2015, 09:47 PM   #6
GABoy's Avatar
We thought we had a seal leak as water got in and fried our inverter. Turned out to be black tank sprayer nozzle was leaking directly above water heater and inverter every time I used it.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 07-11-2015, 08:58 AM   #7
cjd10's Avatar
Same Here
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
door
