Originally Posted by retiredbodyman
I have added an attachment with the picture of the contactors, the first one engages and the second one don't
You still have to answer some basic questions.
1. Using a volt meter what voltage do you get from the big black wire to the white wire? (Should be 115 volt)
2. Using a volt meter what voltage do you get from the big red wire to the white wire? (Should be 115 volts)
3. Using a volt meter what voltage do you get from the big black wire to the big red wire? (Should be about 208 to 220 volts)
After you verify these 3 questions with the proper reading come on back and tell us what you have found.
