Old 09-30-2012, 10:01 PM   #1
Electric brake controller
Has any one installed an eletric brake controller, i was wondering if the coach was pre wired or do you have to start from scratch
wstobasco is offline   Reply With Quote
Old 10-01-2012, 07:31 PM   #2
jd-ford-hd's Avatar
Here ya go..! The link to the post with pics.
2008 Georgetown Brake controller connector
"IF IT AINT GOT A MOTOR, I AINT INTERESTED"
jd-ford-hd is offline   Reply With Quote
Old 10-05-2012, 11:56 PM   #3
Plug It Right
Kind of depends on what year it is. Take a look at MaxBrake™ - Hydraulic over Electric Variable Brake Controller. We've been using it for almost 4 years. Hugs, Di
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.http://www.plugitright.com/5thwheelREDO.html
Dutch & Di is offline   Reply With Quote
Old 10-07-2012, 08:57 PM   #4
i have a 2005 370 and it is wired with the exception of the 12volt power to the trailer, connector was behind the speedo cluster, take that loose and it should be back there
billsinca is offline   Reply With Quote
brake control, brakes
