Old 09-11-2016, 12:46 PM   #1
Electric Fire Place
My fireplace temperature indicator keeps blinking when adjusting the temp! Fireplace does put out heat as well! This relatively new in my 2015 Georgetown 378XL! Any suggestions? Anyone have the website information or someone to contact?
Mike9224 is offline   Reply With Quote
Old 09-11-2016, 08:15 PM   #2
kenandterry's Avatar
I'm a little confused.....doesn't take much some times.
You say the indicator is blinking when making adjustments. Only then? If you're not making adjustments does it still blink?
You said "Fireplace does put out heat as well"
That's what they're supposed to do. So I don't understand this statement.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-17-2016, 02:23 PM   #3
When I unplug the unit and reconnect the unit will power up but when I try to set the temperature level it than starts blinking and will not work and the electric furnace doesn't come on! The unit I have is a combination fireplace (for effect) and electric heater unit as well!
Old 09-17-2016, 02:28 PM   #4
World Wide Wanderer
wahoonc's Avatar
Have you checked the manual to see what it says? Mine defaults to heat off when I turn it on. Never seen it blink. I just checked my files and I apparently don't have a manual for mine... off we go to find one.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 09-17-2016, 02:30 PM   #5
If I had to guess......I'd say you've got a defective motherboard. Your fireplace is more sophisticated than mine. I have turn a dial to set a temperature for heat.....no remote control. Even if you don't have a remote, your controls are probably electronic as opposed to mechanical like my unit.
Are you still under warranty? Can you contact he manufacturer? What brand is it?
Ken and Terry
Old 09-17-2016, 03:14 PM   #6
I am still under warranty so will contact the service dealer! Thanks!
electric
