Old 12-06-2015, 01:36 PM   #1
Electric Fireplace
I have a Georgetown XL 377. Electric fireplace is model #NS-EF06-28. Paper work I have doesn't indicate who manufactured this item, just gives operating instructions. Somehow the fireplace switched from using degrees F to degrees C. Book says to "hold down heater button 10s, will have conversion between degrees C & degrees F". I have not a clue what to do with that statement after looking at fireplace manual controls and the remote. Anyone that can help please do for this old geezer that is clueless.
beezereece is offline   Reply With Quote
Old 12-06-2015, 02:48 PM   #2
kenandterry's Avatar
Can't help your conversion of the fireplace numbers of F versus C but...
0 Celsius is approximately 30 F
10 Celsius is approximately 50 F
20 Celsius is approximately 70F
30 Celsius is approximately 90F
If you're cold crank it up...if you're warm crank it down.
Hope that helps.
kenandterry is offline   Reply With Quote
Old 12-06-2015, 03:00 PM   #3
Pretend you're in Canada.
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 12-06-2015, 03:04 PM   #4
Kenny kustom's Avatar
-30c is cold
+30 is hot
Easy peasy
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 12-06-2015, 03:14 PM   #5
DarrenK's Avatar
-40 is about the same F or C...
DarrenK is offline   Reply With Quote
Old 12-06-2015, 03:52 PM   #6
Crusadernoob's Avatar
Shouldn't need any more help than that!
2006 2500HD Duramax CCSB 2WD
2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 35
Crusadernoob is offline   Reply With Quote
Old 12-06-2015, 04:32 PM   #7
keith52's Avatar
Just a thought, hold down the heat button for 10 seconds and see if it reverts back to degrees in F.
keith52 is online now   Reply With Quote
