Old 07-18-2016, 06:49 PM   #1
Electric Gremlins
Help. I have a 2016 364TS and on our way back today from a weekend getaway, the kitchen TV shut off and wouldn't go back on. The outlets in that area also don't work, the battery bank for the fridge won't turn on, and the A/C doesn't work either. The generator was on. I checked the breaker box and reset all of the breakers and checked the fuses in the panel right next to breaker box (above master bed). Is there somewhere else I should be checking for tripped fuse?
Melvinson404 is offline   Reply With Quote
Old 07-18-2016, 06:54 PM   #2
SeaDog's Avatar
Check the GFI in the bathroom
Retired Navy
2016 Flagstaff 26 FKWS
Old 07-18-2016, 07:01 PM   #3
The GFI outlet doesn't have reset button on it? How do I check it?
Old 07-18-2016, 07:15 PM   #4
SeaDog's Avatar
boy thats a surprise every GFI receptacle I had seen has a test and set buttons, look closer, with that said that receptacle may be protected by a GFI someplace else check the kitchen area and reset if you find it.
Retired Navy
Old 07-18-2016, 07:27 PM   #5
Yeah mine is a Georgetown 364 gasser. I have also never seen GFI without reset button on it but my GFI outlets only have a sticker on them saying GFI. Maybe I'll replace the sticker and they'll work! Uuuuuhhhhhhggggggg........ Frustrating.....
Old 07-18-2016, 07:33 PM   #6
Flybob's Avatar
Check outside outlets for GFCI.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-18-2016, 07:42 PM   #7
I checked outside outlet and it has yet another GFI sticker. Does anyone know where the GFI resets are located in a 2016 364TS?
Old 07-18-2016, 08:09 PM   #8
Tim & Lisa Trempert
Did you check the breakers on the generator itself? Should be two 30 and and one might have blown.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 07-19-2016, 12:32 PM   #9
Turn off one of the AC units. The transfer switch will reset and all power will be restored. This is an on-going issue that I and several other forum members have been fighting with. It seems to be heat related and only when driving.
I will link the other conversations here shortly for you to read. Another forum member is trying a board replacement in his transfer switch and we are awaiting that test.
________________________
2017 Georgetown 364
2011 Dodge Grand Caravan
Stymie71 is offline   Reply With Quote
Old 07-19-2016, 12:33 PM   #10
http://www.forestriverforums.com/for...ue-112106.html
Here is one conversation about this issue.
2017 Georgetown 364
Old 07-19-2016, 12:34 PM   #11
Here is another:
http://www.forestriverforums.com/for...or-113543.html
2017 Georgetown 364
Old 07-19-2016, 07:19 PM   #12
Electric Gremlins
I have the 2016 364ts and mine is in the back bathroom. Yes the one you can not access going down the road unless you have removed the door and put up a curtain 😀. If you think it is the transfer switch. May want to consider putting plugs in place of switch. One of the post on this forum suggested that.
2016 Georgetown 364ts
Snoodledog is offline   Reply With Quote
electric
