Old 06-18-2010, 02:43 PM   #1
diggerrv
diggerrv's Avatar
Unhappy electrical
We have a 2006 Georgetown 340TSSE. Today the center lights and the air conditioner stopped working.
We've checked all the fuses and breakers, all is well. There is no "juice" going to the thermostats.
We've checked the fuse panel in bedroom, at the batteries and the GFIs. Is there another fuse somewhere that we can look?
Any help would be great as we are in the middle of our vacation, in Florida, in June, with no AC.
thank you
diggerrv is offline   Reply With Quote
Old 06-18-2010, 07:06 PM   #2
check breaker on generator
ravenmike is offline   Reply With Quote
Old 06-19-2010, 09:14 PM   #3
Knower of Some Things
converter?
PumaPro is offline   Reply With Quote
Old 06-23-2010, 11:34 AM   #4
Are you running on shore power or genset? If genset, there is a good chance the voltage regulator on the genset has gone south on you. I had this same problem last year, had it fixed at a local RV shop as I was clueless to the problem so I am not sure if this is a user replaceable item or not. Cost was about $135 for the part and another $100 for the labor.
Good luck on it - not a great situation.
Chasracer is offline   Reply With Quote
Old 06-23-2010, 01:25 PM   #5
Herk7769's Avatar
Not familiar with Georgetown
Is your shorepower 220? If so one leg of your 220 could have tripped without tripping the other breaker. Turn both off and reset.
HAM CALLSIGN - KC3FFW
