Old 09-21-2014, 08:55 PM   #11
Phat Phrog Stunt Crew
elind's Avatar
Originally Posted by speedjester View Post
All my outdoor plugs are GFI as well as all my garage plugs.. Something else yesterday it was plugged in all day on the same circuit as the electric fence without issue..( fence was on this morning) the of course the sprinklers are programmed to turn on in that zone at 5pm...I'm leaning toward the moisture tripping the gfi... Unless there is something in the coach that could be tripping it...Could something in the coach itself be tripping it???
All it takes to trip a GFI is moisture around the plug connections. It could be that simple.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-21-2014, 09:00 PM   #12
Well no rain in the near future.. Will shut the sprinklers in that zone off.. If it trips again then I have to look at something tripping it in the coach..
Thanks guys..I appreciate the help..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 09-22-2014, 11:43 AM   #13
May have found my problem.. Outlet added by previous owner was questionable I twisted it and power to coach shut off.. Took cover plate off and found ground was rubbing on bare spot on neutral... Hope this was the issue..
Old 09-22-2014, 08:09 PM   #14
elind's Avatar
Good find!!! That could do it.
2014 Wildcat 327ck
Old 09-23-2014, 09:48 AM   #15
Well it happened again.. What I don't understand suit takes hrs before it trips... Kept it plugged in all day yesterday no issue... Woke up this morning tripped;(... If there was a short to ground wouldn't it trip instantly??? Nothing is on in the MH except the converter..
Old 09-23-2014, 10:01 AM   #16
wmtire's Avatar
Do you have a Suburban water heater, and if so, is the oft hidden electric element switch on by any chance?
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 09-23-2014, 10:06 AM   #17
Wmtire.. I have a suburban water heater but I believe it's just propane..
Old 09-23-2014, 10:10 AM   #18
wmtire's Avatar
That's highly possible, but the link I provided above will show you where to check to make sure it's not electric, as well as propane.
The reason I pointed out this possibility is you may have a problem with the electric element side of the water heater.
Old 09-23-2014, 10:26 AM   #19
TURBS's Avatar
Just an fyi for the op.
normal appliance amp draws
Old 09-23-2014, 07:04 PM   #20
jergeod's Avatar
You mentioned you have a freezer on that same line as the motorhome, how many amps is that breaker? The freezer may be drawing almost max of the breaker then with the converter of the motorhome each time the freezer kicks on it trips the gfi or if the freezer is running and the converter jumps on gfi trips. Just a thought.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
electric, electrical
