03-15-2018, 08:55 AM
Electrical Issue in Georgetown
Gee you guys. My Georgetown uses a 50 Amp Service or only half of the things work. Like only one Air Conditioner. The 50 Amp Service provides 110 Volts on each leg of the Plug.
David L Horton
2016 Georgetown 328
03-15-2018, 09:10 AM
If I understand you correctly, you are saying from hot to ground is 110 volts and neutral to ground is also 110 volts? If so it sounds like you have a hookup problem and it will fry most appliances and electronics in your coach.
Are you uses an EMS system of any kind?
2013 Georgetown XL 378
2008 Honda CR-V
03-15-2018, 09:19 AM
So,you're saying if you use a 30 amp adapter you have a dead leg??? If so your adapter is bad.
03-15-2018, 10:00 AM
No only 120 per Leg.
David L Horton
2016 Georgetown 328
03-15-2018, 10:29 AM
So, 240 volts across the hot and neutral terminals (legs) of the plug receptacle?
2008 Honda CR-V
03-15-2018, 10:47 AM
Seems you don't realize a 50a service is TWO hot legs , a neutral and a ground.
03-15-2018, 10:49 AM
Here's some more that might help...
03-15-2018, 10:51 AM
I do understand how it is wired up. I just don't understand the OPs comment on 110 volt of each leg from a 110 receptacle or from the service pole. I'll try rereading his posts again.
2008 Honda CR-V
03-15-2018, 10:53 AM
Sorry, I thought you were trying to get verification of your statement... you were actually asking the OP a question.
My bad.
03-15-2018, 10:55 AM
That's cool. No harm done. This is the down side to posts. Too bad we just can't sit around the camp fire and discuss the issues. That's always more fun.
2008 Honda CR-V
03-15-2018, 11:01 AM
No, 110 to 120 per leg.
David L Horton
2016 Georgetown 328
03-15-2018, 11:03 AM
At the service pole or inside your RV?
2008 Honda CR-V
03-15-2018, 11:39 AM
Dave, your questions are a bit cryptic.
We are trying to understand what you are asking but your statements of just a few words do not make much sense.
If you are saying you are hooked up to a 50a service and only half of the things in your rig works then you have a power problem somewhere.
A 50a service provides TWO legs of 120v into your rig.
You have to start with the basics...
Are you connected to a 50a service?
Do you have a meter? (and know how to use it?)
Have you checked power at the pedestal with a meter?
Have you checked breakers?
If you are saying you are connected to a 30a service with a 50/30 adapter and only half your outlets work, then you have a bad adapter as was mentioned.
Give us a little something to go on and someone will be sure to help.
See the wiring schematics I posted earlier in the thread.
On the other hand... maybe you aren't asking a question at all and simply making a statement?
03-15-2018, 02:41 PM
I think that if you draw your plug, show your voltage measurement, everyone here could give you a better answer.
Tam & Ha from Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
03-15-2018, 05:55 PM
03-15-2018, 05:58 PM
110 and 120 is the same thing. Please explain what you are doing to only have 1/2 of your electric service when using 30 amp hook up.
03-15-2018, 06:40 PM
I read this to say: Unless I use my 50 amp hook up only 1/2 of the things work.
He seems to understand a 50 amp service. I think he has one of those defective adapters we have learned about in another thread.
Hopefully, he will answer and expound on his problem
