Old 01-26-2015, 02:32 PM   #1
Krazymace's Avatar
Electrical Issues
Wife & I are leaving next Mon for 3 months in AZ & So Cal. Normally I park my GT in driveway for ease of loading. However, when I plug it into a 20 amp GFI outlet on my front porch, it trips that GFI circuit. I plugged it into another GFI with same result. Then I ran my cord into the house and plugged into a non GFI outlet. That caused the breaker to trip on my house panel. I tried isolating the problem in my coach by shutting off all breakers including the main. As soon as I turn the main on, the GFI and or breaker on the house trips. Everything is fine if on 30 or 50 amp.
Krazymace is offline   Reply With Quote
Old 01-26-2015, 02:45 PM   #2
Flybob's Avatar
Little confusing, Have you tried it on a 30/50 circuit since you had this problem? Check to insure that the water heater switch us not on. If you energize the electric element in the WH without the WH being full of water, it will instantly burn out the element and short it. This will cause the RV to trip a GFI or breaker if plugged in.,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-26-2015, 02:56 PM   #3
BombDoc's Avatar
This type thing can drive you crazy. Something in your rig is causing a short and tripping your GFCI's and house breaker. I had a similar issue with my 5th Wheel. The exact same thing would happen when I plugged into 20amp shore power. I disconnected from shore power and went to the 5er, opened one slide, then plugged into 20amp. If it tripped, I unplugged, reset and opened the other slide, it didn't trip. I then crawled underneath to find one of the electrical wires had been stripped in the slide in and out process. I wrapped it with electrical tape and problem solved until I went to Annual Rally in Goshen and FR replaced the wiring harness. It took a while, to figure out what was tripping the breakers. Just be patient and you might be able to figure out what is causing the short. As FlyBob suggested, the WH would be a good start.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 01-26-2015, 03:37 PM   #4
bend302's Avatar
It may be that you are simply pulling more than 20 amps. Water heater is 10-12A and converter pulls 7 or 8 A and refrigerator pulls 3 Amp. Then any plugged in AC items will try to turn on.
Make sure heaters, water heaters etc. are off then try again.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 01-26-2015, 03:43 PM   #5
TURBS's Avatar
You really shouldn't plug into a gfci.
With that being said your household outlets are 15 amp not 20.
You may be drawing to much juice.
Old 01-26-2015, 03:48 PM   #6
TURBS's Avatar
See the difference?
Old 01-26-2015, 04:07 PM   #7
Krazymace's Avatar
One thing I should have added. I have always been able to plug into a GFI before with no problems. Also, nothing is on in the MH. Thanks for replies. Wish I was an electrician!
Old 01-26-2015, 04:08 PM   #8
Krazymace's Avatar
I have a 20 amp for Xmas lites.
Old 01-26-2015, 04:09 PM   #9
TURBS's Avatar
Shut off all the breakers in you mh distribution panel then try plugging in.
If it doesn't trip then turn one on at a time till it does..
Old 01-26-2015, 04:09 PM   #10
TURBS's Avatar
Very good!
Normally that's not the case
electric, electrical
