Old 08-13-2015, 08:27 AM   #1
Electrical problems
Microwave stopped working last night. Fuses and breaker are okay. Any suggestions?
Also, kitchen side of RV lost electricity to elec. plug. Again, fuses and breakers are fine.
Larry Tiner is offline   Reply With Quote
Old 08-13-2015, 08:35 AM   #2
wmtire's Avatar
Check your gfci and see if it's tripped. You usually have them near sinks in the kitchen and bathrooms. If the master gfci outlet trips, then all the other outlets wired to it in succession will not function. These gfci outlets are also famous for wires coming loose in them, and just being faulty too.
2011 Flagstaff 831 RLBSS
Old 08-13-2015, 08:36 AM   #3
Flybob's Avatar
Check GFI. Note that FR uses one GFI to protect itself and several down stream outlets so GFI may not be located in same area as non working appliance
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-13-2015, 08:37 AM   #4
Batts-toy's Avatar
After you check the gfci suggested above and still not solved we will need some information to be able to help you:
Are you boondocking and running a generator?
Are you plugged into shore power?
Are you running these things from an inverter?
Do you have 30 amp service or 50 amp service?
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-13-2015, 11:16 AM   #5
Great advice! It was the gfci! Stupid me!!
Thanks for your help, guys!
electric, electrical
