Old 09-19-2016, 01:48 PM   #1
Empty Fresh Water
I have a 335ds and when I leave a campsite, I'd like to be able to dump some fresh water so I'm not carrying unnecessary weight. Other than crawling under the rig and using the low point drains, I can't see how to do it. Thanks for your help.
bdeye is offline   Reply With Quote
Old 09-19-2016, 01:53 PM   #2
Low point drains do not typically drain the fresh water tank.
Look around for another drain.
You may still have to crawl under though to drain it.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-19-2016, 01:55 PM   #3
brookstone345sa's Avatar
I switch the valve to fresh water tank, turn on water pump and drain it into grey tank, turning on faucet. Then dump as normal
brookstone345sa is offline   Reply With Quote
Old 09-19-2016, 01:56 PM   #4
Sorry that's the only way open drain ad turn on pump
Don
Georgetown 335DS 2013
Toad 2016 Ford Focus se
Donlock is offline   Reply With Quote
Old 09-19-2016, 03:35 PM   #5
Marksha83's Avatar
I just went through finding the fresh water drain on our 335. Behind the passenger side tires up underneath is two pipes. The pipe that is lower to the ground is the low point drain. The pipe slightly higher is the fresh water drain. Easy to get to.
2014 Forest River Georgetown 335
SOLD: 2016 Coachmen Leprechaun 319DS Ford E450 Chassis Triton V10
Marksha83 is offline   Reply With Quote
Old 09-19-2016, 03:44 PM   #6
I put valves on mine.
Don
fresh water, water
