Old 12-09-2017, 05:49 PM   #1
engine heater
cab heat blows luke warm at op temp
largti is offline   Reply With Quote
Old 12-09-2017, 06:39 PM   #2
Scoundrel
HangDiver's Avatar
"Brevity is the soul of wit" - William Shakespeare. I don't think that applies here.
2014 Micro Lite 19fd
My boss texted me: "Send me one of your funny jokes."
I replied: "I'm working right now. I'll send you one later." He texted back: "Thats fantastic! Send me another one!"
HangDiver is online now   Reply With Quote
Old 12-10-2017, 07:18 AM   #3
Sounds like either the engine thermostat or a door n the hvac unit isnít operating as it should. Is the engine getting up to the 190* range? Some have a hot water valve, be sure itís open. If itís an older unit, the heater core may be covered with debris preventing heat transfer. Check both heater hoses to be sure theyíre hot, core could be stopped up internally.
Hope some of this helps.
Gbegoon is offline   Reply With Quote
Old 12-11-2017, 12:55 PM   #4
2013 335 only 10000 miles cant find a valve
Old 12-11-2017, 07:16 PM   #5
I have a 2014 Georgetown 351DS. I have the same issue with the heater. Iím wondering if part of it is a perception issue. The sucker puts out much more air volume than a car. Could it be that the large volume of air makes it feel cooler at a distance from the vent?
EricNJ is offline   Reply With Quote
Old 12-11-2017, 07:20 PM   #6
Mine is a 2014 378TS, it will run you out it puts out so much heat.
Old 12-11-2017, 07:34 PM   #7
Hmmnnn. Well that means that there is definitely something wrong with ours then.
Old 12-11-2017, 07:47 PM   #8
Iwannacamp's Avatar
Put a thermometer in the duct it should put out 130 or so degree air with operating temp engine. Does the engine reach normal operating temp? If so and it doesnít there may be an issue. Make sure itís on max or recirculate not blend air. Pic of control might help if you arenít sure. DWís car is touch screen and knobs and is confusing. I swear she doesnít know how to operate it(if I want her to know I said that I will tell her).
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 12-12-2017, 02:18 PM   #9
temp
checked with air cond. thermometer blows only 90 degrees at operating temp
heater
