Old 12-22-2014, 02:51 PM   #1
Engine noise Reduction
Has any one tackled the job of reducing sound in the front part of a Georgetown 360. I have padded the doghouse which reduced the sound somewhat. I looked under the hood stuck my head under and looked up there was only foam there....if I pad this will this help..
Dogpound is offline   Reply With Quote
Old 12-22-2014, 03:48 PM   #2
Iggy's Avatar
I know one person here that spent a lot of time buying expensive sound proofing for the dog house and in the engine and wheel wells.
If I remember correctly the issue was how to install them that they will stay in place in the engine compartment top area.
I don't think you can stop it but the dog house is the only place I can see spending the money. The rest of the areas are hard to get into and personally not worth the effort. This is my thoughts only and not others.
Someone may have more information or the actual installer may still stop by here.
Old 12-22-2014, 04:43 PM   #3
Its not sound proofing the wheel welds ,,,I believe the noise is coming from under the dash ....if you open the hood and look up after you put your head inside you will see that there is only a foam pad under the portion of the dash that is over the engine compartment,
Old 12-22-2014, 06:59 PM   #4
jergeod's Avatar
What I found that reduced a lot of noise for me was 1 1/2" insulation board (foam) did the complete dog house area sides and top. You need to cut lots of peices to make it solid and attach with liquid nails, been on 1 year and counting. You could add up in where you are talking also. HD or Lowes both carry it.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 12-22-2014, 07:14 PM   #5
Did you add insulation board in the hood area,,,,open the hood '''put your head inside then look up. I only saw a foam pad
Old 12-22-2014, 10:33 PM   #6
jergeod's Avatar
Mine might be a little differant being and 06, no I didn't even look in that area but when I wake her up from her winter nap in the spring I sure will look at that.
George & Jerri
06 GT 340 TSSE
USMC
Old 12-24-2014, 05:52 PM   #7
abjb's Avatar
here's the thread.
Soundproofing
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 12-28-2014, 05:40 PM   #8
43D18's Avatar
Hmm. Never considered the noise that much of an issue to us.
Mike & Suz
2014 Georgetown 351
Pontiac Vibe toad
Buck & Patsy, the boston-mix guard dogs
43D18 is offline   Reply With Quote
Old 01-03-2015, 10:54 AM   #9
kenandterry's Avatar
The only time we can REALLY hear the engine, is if it shifts down a couple of gears for a significant hill climb.
Other than that, it's basically wind noise and/or tire noise on the pavement.
I improved the speakers significantly in our cabin using the stock in-dash stereo system, and for the most part..........ambient noise is not an issue.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 01-03-2015, 11:19 AM   #10
There is some noise that comes from under the dash which for the most part is a piece of plywood with a foam pad on the bottom. Rather than try putting more insolation under the dash, probably add a dash cover.
