Old 11-07-2014, 07:40 PM   #21
GABoy's Avatar
Originally Posted by Dijoeboss View Post
Did they change out the timing chains and guides and chain tensioners? ( I can only assume they did... )
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Yes. I figure the trouble is around a piston. They suspect #2.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 11-10-2014, 12:39 PM   #22
GABoy's Avatar
Update:
I'm getting an entire new engine! They tore it down and found #2 piston ring broke and sleeve scarred up. So entire new long block.
Chevy Colorado Crew
Old 11-10-2014, 01:02 PM   #23
Dijoeboss's Avatar
Thanks for the update! That's probably the best news considering the circumstances! ( best news would have been that it never had a problem, but.... )
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
Dijoeboss is offline   Reply With Quote
Old 11-10-2014, 01:31 PM   #24
GABoy's Avatar
Originally Posted by tjvpga View Post
Ford towed it under warranty. They towed it to a Walmart parking lot until they can find a dealer that can fix it. Then they said they will tow it again to the dealer.
tjvpga,
Any news or update or yours?
Chevy Colorado Crew
Old 11-10-2014, 01:51 PM   #25
Iggy's Avatar
Originally Posted by GABoy View Post
Update:
I would love to see how they get it in there.
Probably from below after they remove the whole front suspension.
If you have a chance to take a few pictures would be fun as well as interesting.
But at least it will be installed by Ford is a good thing.
Old 11-10-2014, 01:56 PM   #26
GABoy's Avatar
Yes. They told me they would drop it out from under coach removing suspension.
Wander if I'll have to redo chf when I get it back?
Chevy Colorado Crew
Old 11-10-2014, 03:01 PM   #27
Iggy's Avatar
What di you mean by this sentence?
"Wander if I'll have to redo chf when I get it back? "
I would ask them to do a front end alignment if they remove the steering.
Old 11-10-2014, 05:49 PM   #28
GABoy's Avatar
I had already done the cheap handling fix. So when they remove the front suspension and then reinstall post engine install, I assume that will install front sway bars back to factory hole location. It made a big difference to me in handling. Not so much roll feel.
I will definitely ask about front end alignment as it had just been done with in the first 90 days from purchase under warranty.
Chevy Colorado Crew
Old 11-13-2014, 12:30 PM   #29
GABoy, are you as calm about all of this as your postings? Wow!
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 11-13-2014, 12:55 PM   #30
GABoy's Avatar
I'm a pretty relaxed fellow. I know crap happens! We love the 351. Never thought the ford power plant would have had issues. At first I was a little worked up about it all. It's been over a month now and I'm getting a new engine which is what I wanted as I believe it's best option here. I will definitely put her through the paces to see if she's all good. I'm a little anxious to get her back. Should get her next week. DW is teacher and I also still work so not full timing. We have missed one weekend trip with her had to get hotel. I don't know how a full timer would handle this. Be out of their home for a month!
Chevy Colorado Crew
