Old 06-22-2016, 03:40 PM   #1
entrance door gas piston
Hi. We have a 2012 georgetown 350f and having trouble with entry piston, it can off and let door hit motorhome. Does anyone know what part number it is or length and pressure size they are. Want to replace it Thanks
bojack is offline   Reply With Quote
Old 06-22-2016, 03:46 PM   #2
chrisbailey13's Avatar
I believe it is a 20" 20lbs shock. if you still have it you can take it into your local Camping World...they have most of them in stock.
http://www.campingworld.com/search/i...y&Nty=1&Ntpc=1
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 06-22-2016, 06:42 PM   #3
Thank you very much !!!!!!!!!!!!!!!
Old 06-23-2016, 11:17 AM   #4
Get a 10lb from amazon,
JR Products GSNI-5300-10 Gas Spring, doesn't slam open like the 20lb version and it wont bend the bracket it's held onto the door with. It's a direct replacement.
Watertown is offline   Reply With Quote
Old 06-23-2016, 12:21 PM   #5
If the plastic end came off it may be stripped out. I found a replacement end at an RV store that had a brass insert that should not strip out. Easy fix.
2016 Georgetown 328ts
2015 Fiat 500 Toad
db7512 is offline   Reply With Quote
Old 06-23-2016, 12:47 PM   #6
Havasu Bill's Avatar
Any auto parts store has them. Just take it in or get the model and rating.
I replaced mine that way and finally got rid of it and put a 6" hatch stop/latch on. I like it better this way.
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
Havasu Bill is online now   Reply With Quote
Old 06-23-2016, 02:50 PM   #7
Front door entry piston rod
I have a 2012 Riverforest Georgetown, the piston on my entry door, also went out. I called a company in California that was on the piston with the part number. I paid over $36.00 for it. When I got it I checked to see what it was. So i order one from Amazon. To have a spare. This is the part I ordered from Amazon.
RV Designer Collection G24 20" Gas Prop - 15 lb. Capacity
Sold by: Amazon.com LLC
$16.54
Camping world only had 10 lbs and 20 lbs. My rv called for a 15 lbs.
Hope this helps you.
rgm1938 USMC
rgm1938 is offline   Reply With Quote
door, gas
